October 06, 2026, 02:49:16 am
Hoffman Amps Forum image Author Topic: Univalve  (Read 5143 times)
Offline dpm309
    • Matthews Amps
Univalve
« on: March 14, 2018, 12:53:33 pm »
Working on a dead THD Univalve that was playing fine and then a static/sweep sound came out of the speakers and the amp went dead. The noise was like when I blew the PT on my Tweed Deluxe clone, twice. Tubes light up but I am getting no power at all from the HV secondaries and no B+ voltage on the output of the bridge rectifier (BR1). Fuses are all good. Tried checking the resistance on the primary and secondaries as per the amp debugging page and showed to be within the recommendations. Before I order a new one, is there anything else I should be looking at? What could of caused the sudden failure of the PT? The schematics can be found on Doug's schematic page.
Re: Univalve
« Reply #1 on: March 14, 2018, 01:34:51 pm »
Do you measure 120VAC ***ACROSS*** the actual primary leads? IOW, is 120VAC actually getting to the PT primary?
Offline dpm309
    • Matthews Amps
Re: Univalve
« Reply #2 on: March 14, 2018, 02:02:33 pm »
Yes, I am getting 120VAC to the PT primary. Rechecked the HV fuse and it is blown. Could not tell by a visual inspection. Put in another .25amp SB fuse and seems to be working. Checked the amp out with the light limiter and there does not seem to be any shorts. Will let it run awhile to see if it did the trick.
I can't believe I didn't double check before posting. Will always check for continuity on the fuses in the future!
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: Univalve
« Reply #3 on: March 16, 2018, 05:17:40 pm »
Just be aware if it blows again, it's a hint something else is wrong, but sometimes after years of use and occasional wiring spikes at the wall, they can just 'go' sometimes
~Phil
Phil Davis
tUber Nerd =|D
Offline dpm309
    • Matthews Amps
Re: Univalve
« Reply #4 on: March 17, 2018, 11:02:20 am »
Have been running the amp for awhile with no problems. Turns out that the amp was switched to high power with a 6V6 (THD says to use Lo power only with a 6V6) and blew shortly after that. I am guessing a power surge caused by switching from low to high power without switching off the standby caused this. Better than blowing the transformers.
Re: Univalve
« Reply #5 on: March 17, 2018, 07:23:28 pm »
Put in a switch to sense the height of the bottle. If under 2.8", switch to lo-power.
Or just accept the easy(?) work.
