July 29, 2026, 05:57:29 pm
Hoffman Amps Forum image Author Topic: Single ended EL84  (Read 42690 times)
Offline rake
Single ended EL84
« on: March 18, 2018, 01:53:23 pm »
Any good schematics foe a single ended EL84 practice amp?
Or, has any of y'all built one?
Re: Single ended EL84
« Reply #1 on: March 18, 2018, 02:02:40 pm »
Schedule 40. Read about it here...
     http://el34world.com/projects/Schedule40.htm
Here's the schematic...
« Reply #2 on: March 18, 2018, 02:07:38 pm »
« Reply #3 on: March 18, 2018, 02:24:02 pm »
here's a couple I've built
Offline rake
« Reply #4 on: March 18, 2018, 02:29:32 pm »
Thanks guys!
« Reply #5 on: March 19, 2018, 02:29:21 am »
This one rocks!
This is the schematic for the above amp.
Offline rake
« Reply #6 on: March 19, 2018, 07:56:46 am »
That gives me a lot to work with.
Thinking one of them with a reverb circuit
would make a great mic'ed up small club rig.
Let the little amp make great tone and
let all that Crown and JBL stuff make it really loud!  LOL!  :l2:
Offline Menryk
« Reply #7 on: April 01, 2018, 01:46:52 pm »
Which of these all schematics (SE EL84) show amp with clean and good sound without distortions?
« Last Edit: April 01, 2018, 01:49:37 pm by Menryk »
« Reply #8 on: April 02, 2018, 03:01:37 pm »
I think a 6V6 SE will be more adapt for your necessity
« Reply #9 on: April 02, 2018, 06:54:06 pm »
as K states - 6V6/6F6. etc.. EL84 is a high gm tube. very easy to overdrive.
« Reply #10 on: April 02, 2018, 08:36:23 pm »
as K states
you really need to tweak to keep from distorting, although I did do a mono-block using a quad of 84's
2 great speakers and she trended favorable with most of my deaf audio friends  :laugh:
Offline Menryk
« Reply #11 on: April 03, 2018, 04:24:26 pm »
Thanks guys,
sorry but I didn't tell you that I need stereo amp but not for quitar.
To amplifing signal from tuner or gramophon (without tone correction).
Usually I use EL84 in all my amps. Because of that I asked about EL84.
From many months I tried to find good schematic to my purpose and to this time I don't find ready to applying schematic.
Every time when I see some schematic It means that I need change it to my purpose.
Now I work with amp (this time to the quitar) and I need change many things.
So do you have the best example of SE with ECC83 (12AX7) and EL84, Hi-Fi amp in your opinion?
« Last Edit: April 03, 2018, 04:37:16 pm by Menryk »
« Reply #12 on: April 03, 2018, 08:57:02 pm »
here's 2 HIFIsh builds, both sounded good within the "clean" range, the PSE was clean to about 70% volume
the QSE has no controls, simply driver PA.  the QSE I drove 2 Audio Nirvana 8" full range.  the QSE schematic is only a "guideline" I know it was tweaked n not documented  :think1:
Offline galtjunk
« Reply #13 on: April 04, 2018, 04:11:04 am »
I built a Decware  stereo single ended sv83 amp.
You can use EL-84's if you like but I prefer the russian 6p15.
You can get a circuit board from them or you can build it point to point.
I built mine without the board.
http://www.decware.com/newsite/SE84CDIY.htm
All of the info you need can be found at http://www.decware.com/newsite/SE84CDIY.htm
It is bridgeable so you can build 2 and double the power.
It sounds great.
I may still have a visio layout if you need one.
Offline Menryk
« Reply #14 on: April 04, 2018, 07:51:44 am »
Thanks guys very much,
I will check all your suggestions.
Shooter - interesting, especially preamp.
I don't see volume potentiometer.
Galtjunk - very interesting proposal.
What is voltage in point B.
In A point is 346V - I'm not sure that my transformer has this high voltage.
« Last Edit: April 04, 2018, 08:14:11 am by Menryk »
« Reply #15 on: April 04, 2018, 08:53:14 am »
none to see, it's built as a PA amp, vol n tone happen in whatever you jack in
« Reply #16 on: April 04, 2018, 03:10:50 pm »
Sorry, late to the party.  I have built this and played it, but it was for a freind's son.  Great practice amp and has all the bells needed IMO.
Offline galtjunk
« Reply #17 on: April 06, 2018, 04:15:07 am »
I built it with the suggested Edcor transformers.
I think A shows 328 volts but I don't have a reading for B.
There is a set of videos on youtube showing the construction process.
Search for DIY Zen Triode tube amplifier.
There should be 12 videos.
Offline Menryk
« Reply #18 on: April 06, 2018, 01:37:19 pm »
Thanks galtjunk,
I will try to check.
M.
