August 05, 2026, 05:08:43 pm
Hoffman Amps Forum image Author Topic: Redundant fuse - The better use ?  (Read 4716 times)
« on: March 24, 2018, 05:44:18 pm »
I'm placing on an amp an IEC inlet, in the same unit there is a line filter, an ON/OFF switch and two fuse holders
I'll use one of the fuses for the line and I'm wondering which will be the better use for the other fuse
the other wire of the line ? - B+ protection ? - Heaters ?
Please suggestions
« Last Edit: March 24, 2018, 05:46:40 pm by kagliostro »
Re: Redundant fuse - The better use ?
« Reply #1 on: March 24, 2018, 08:11:58 pm »
I'd keep the wall-power module ONLY wall-power stuff.
I don't like the idea of bringing "safer" wiring on the PT secondary back next to the wall-power.
Your regulations encourage double-pole switches. Double fuses on the wall-power may be a similar thought.
« Reply #2 on: March 25, 2018, 01:43:06 am »
I forgot to say it is a 3 W  amp and  B+ is near line voltage (260v)
However I'll follow your council, as you say the switch is  DPST
Offline trobbins
    • Tim's projects and info
« Reply #3 on: March 25, 2018, 01:38:46 pm »
K, has that really got two fused connections!
Do you have a link to part spec?
« Reply #4 on: March 25, 2018, 03:09:43 pm »
Ciao Tim
https://docs-emea.rs-online.com/webdocs/140a/0900766b8140a4e0.pdf
https://uk.rs-online.com/web/p/iec-filters/8826888/
At a Ham Fest I got 2 (new) for 5 € I was surprised when I've seen the retail price is more than 20 € each  :huh:
I've been lucky
Offline trobbins
« Reply #5 on: March 25, 2018, 04:46:52 pm »
Hmmm.  So G,H,J, K terminals in datasheet connect to the two fuse terminals?
Never come across that before  :w2:
« Reply #6 on: March 25, 2018, 06:11:42 pm »
Yes, tomorrow I'll post a pair of photo
(on 21-22 april there will be one other Electronic Fier with Radioamateur Flea Market, I think I'll see the guy from which I got the inlet and I'll get some others, if he has more)
« Last Edit: March 25, 2018, 06:16:26 pm by kagliostro »
« Reply #7 on: March 26, 2018, 06:34:50 am »
Here the photo
you can see the small door and inside two sledges where you place the fuses
