August 29, 2026, 03:56:32 pm
Hoffman Amps Forum image Author Topic: 230 volt pilot light  (Read 6726 times)
Offline Oddvar
« on: April 09, 2018, 10:08:42 am »
Hi, is there any tips on where to buy 230v pilot light for tube amp?
Offline 92Volts
Re: 230 volt pilot light
« Reply #1 on: April 09, 2018, 10:19:04 am »
Standard pilot lights are 6.3v, which is (usually) produced by your transformer for tube filaments regardless of your primary/wall voltage.
If you can't/don't want to do it that way... I'm not sure standard pilot lamp holders/sockets are rated for 230v even if you COULD find a suitable bulb.
You might want to look for a switch or power socket with a built in light. Whichever types are sold in your country would (hopefully) operate on 230v.
Offline BruceF
« Reply #2 on: April 09, 2018, 10:32:49 am »
Offline Leevi
    • Rikstone
« Reply #3 on: April 09, 2018, 11:52:14 am »
Offline rake
« Reply #4 on: April 09, 2018, 12:03:47 pm »
I just ordered a 230v neon panel lamp from Mouser Electronics.
Solid state has no soul........
Offline Oddvar
« Reply #5 on: April 10, 2018, 08:52:25 am »
On the Marshall 18 watt Hoffman layout the pilot light seems to be between the two 230v leads?  (I am from Norway)
Offline Leevi
    • Rikstone
« Reply #6 on: April 10, 2018, 09:23:28 am »
(I am from Norway)
... neighboring country;) they deliver to Norway
/Leevi
« Reply #7 on: April 10, 2018, 09:23:49 am »
As pilot light do you mean only the lamp or all the unit (lamp + mount unit) ?
« Reply #8 on: April 10, 2018, 10:20:53 am »
Hoffman's Stout is wired for 120VAC operation. The pilot lamp is a 120VAC neon lamp assembly available in his parts store. You can use a 120V neon pilot light assembly by putting a 220K resistor in series. But, since 240VAC neon pilot light assemblies are readily available, you should just use one of those.
« Reply #9 on: April 10, 2018, 11:28:50 am »
I was asking because is not difficult also to find this kind of unit (good if you have few space)
« Reply #10 on: April 10, 2018, 12:56:26 pm »
You can steal one out of a toaster or other simple 230V appliance. Look inside and be sure it connects to the wall-cord, not on the far (low volt) side of a power transformer.
