September 15, 2026, 08:32:50 am
Hoffman Amps Forum image Author Topic: Brown Eye-ish Amp in Princeton Reverb Chassis  (Read 29399 times)
Offline Ledzepp007
« on: April 10, 2018, 09:16:40 pm »
In my ongoing attempt to design a higher-gain amp to put in a Princeton Reverb chassis, I came up with a variation on that "Dirty Princeton" theme I had posted earlier. This time, it's SS rectified with more filtering and higher gain. The preamp is based on the Friedman BE. Feel free to check out my schematic and make suggestions as you want. Thanks!
Re: Brown Eye-ish Amp in Princeton Reverb Chassis
« Reply #1 on: April 11, 2018, 01:05:04 pm »
You probably do not want 470uFd on the cathode of that cathode-follower.
For any likely guitar input, stage 2 will be grossly overloaded and stage 3 will be OVER-OVER-LOADED before you get to the first gain knob.
Offline Ledzepp007
« Reply #2 on: April 11, 2018, 02:40:00 pm »
Attached is the schematic that I was inspired by. Did I read it wrong?
« Reply #3 on: April 11, 2018, 09:47:12 pm »
That plan has more interstage attenuation than yours.
It still looks wicked.
Build it so you can change things to taste.
Offline MFowler
« Reply #4 on: April 12, 2018, 04:58:24 am »
No schematic but Ceriatone's AH50 is based off Friedman BE50 so there is a layout to review if you wish.
Offline Ledzepp007
« Reply #5 on: April 12, 2018, 12:52:39 pm »
So, I relooked at the original schematic, and it looks like the first triode is actually for a clean channel, so I’ve got one too many gain stages.
Offline jokn
« Reply #6 on: April 13, 2018, 02:43:21 am »
The first (input) triode is for both channels. The clean channel adds a tone stack and another triode before the effects loop and PI, while the dirty channel adds four more stages after the input stage. Looks to me that you have the same five-triode string on your plan. I’ve built a similar amp, but mine had the dirty channel gain pot after the channel switch relay, before the second stage.
Offline Ledzepp007
« Reply #7 on: April 13, 2018, 08:56:07 am »
Ahhhh. Yes, I see it now. Relays totally scramble my brain when it comes to schematics.
My initial schematic should be close then. It does seem weird not to have a gain pit after the first gain stage.
« Reply #8 on: April 13, 2018, 09:06:01 am »
Yes. That cap is 500"P"f in the schematic....just there as a switchable treble dumper. If you don't make it switchable (as it appears in your version of the schematic) then you're just always dumping treble there. Wrong or right is subjective.
« Reply #9 on: April 13, 2018, 09:11:38 am »
Put one in. This is your chance. It's your design.
Offline purpletele
    • Vallis Enterprises, Inc.
« Reply #10 on: April 13, 2018, 11:32:18 pm »
I wonder what AH stands for.  ceritone certainly has a sense of humor.
Offline Ledzepp007
« Reply #11 on: April 14, 2018, 03:55:01 pm »
Lol. Didn't even think about that.
I did some more "work." I updated my original schematic with proper attenuation and did a new layout. Those are attached.
I also attempted a two channel version (with a clean channel). I've never done a two channel amp, so it could be a dumpster fire.
Offline Ledzepp007
« Reply #12 on: April 14, 2018, 03:57:04 pm »
Here is the two channel layout, with an attempt at channel switching. You may LOL.
Also attached is a photo with a proposed layout for the iron.
Offline Ledzepp007
« Reply #13 on: April 14, 2018, 04:05:02 pm »
Whoops! Forgot to connect V2 P6. New layout attached.
Offline Ledzepp007
« Reply #14 on: April 14, 2018, 09:15:21 pm »
Would there be too much voltage on the toggle switch?
Offline jokn
« Reply #15 on: April 15, 2018, 02:19:17 am »
I think the switch should be fine. Many are rated at 125 VAC and several amps. You seem to be missing a grid reference for V1b, btw.
Offline Ledzepp007
« Reply #16 on: April 15, 2018, 10:05:33 am »
Thanks. Would the switch the way I have it wired switch between the two channels?
« Reply #17 on: April 15, 2018, 08:28:34 pm »
Your schematic doesn't show a channel switch or 2 channels
Offline Ledzepp007
« Reply #18 on: April 16, 2018, 02:45:11 pm »
I haven’t made a schematic for the second channel yet
Offline Ledzepp007
« Reply #19 on: April 22, 2018, 08:08:40 pm »
Sorry to beat a dead horse, but here is a two channel schematic.
Offline Bantam
  • I love Tube amps,so lid state amps,
« Reply #20 on: April 23, 2018, 04:00:56 am »
Howdy...not sure what you're going for, but If it's a compact version of BE, Cameron, etc, my thoughts are the high gainers use big iron, high V. , Multiple ohm speaker taps, 4x12 cabs, etc.
Basically, dirty front, tight beefy end.   That said, I still look forward to hearing. Just thinking 6v6's, lower voltage, etc, already gives dirt, but who knows.    What are/is final expectations/use? Studio, grind in a coffee house (oops, sorry for that) heh!
« Reply #21 on: April 23, 2018, 05:51:21 am »
Concerning the channel switch... Your schematic does not match your layout. Need to move that .0022 and 1M to the plate of V1A on the schematic to match layout. Also, V1B must have a resistor from grid to ground. Other than that, switch should change channels. There should be no dc voltage on the switch.
« Reply #22 on: April 23, 2018, 08:19:31 am »
You're still gonna want to get rid of that cap on V3 pin 8, or at least change the value and voltage rating.
As it is now, it's a firecracker.
« Reply #23 on: April 23, 2018, 09:53:02 am »
Yes, get rid of it. There should be no cap on the cathode of a cathode follower.
Offline Ledzepp007
« Reply #24 on: April 23, 2018, 01:35:16 pm »
Low volume recording amp. I tried to up the tail resistor on the phase inverter to limit power tube distortion, but we shall see.
Offline Ledzepp007
« Reply #25 on: April 23, 2018, 01:36:59 pm »
Forgive my being a dummy. I thought I saw a cathode bypass cap on the original schematic. I thought it was weird as well.
« Reply #26 on: April 23, 2018, 01:48:56 pm »
There is a cap in that position on the "inspired by" schematic you posted, it's just not intended to be a cathode bypass cap.
See reply #8
If you're gonna put it in, make sure it's high voltage handling
« Last Edit: April 23, 2018, 01:51:16 pm by SILVERGUN »
« Reply #27 on: April 23, 2018, 02:07:08 pm »
There is a 500pF cap that will dump some high freq stuff if you throw the switch. But a 25µF will dump every bit of your guitar signal, leaving you with a quiet amp... until that low voltage cap explodes.   :icon_biggrin:
Offline Ledzepp007
« Reply #28 on: April 25, 2018, 11:33:33 am »
LOL. I can see it now.
BTW, why would I need a resistor from grid to group on V1B?
« Reply #29 on: April 25, 2018, 11:56:17 am »
The grid and cathode referenced to ground and each other provide bias for the tube, with no reference on the grid it "floats in the wind", causing all manner of odd and weird issues that will drive you down many rabbit holes
Offline Ledzepp007
« Reply #30 on: April 27, 2018, 03:12:08 pm »
Ahhhh. Thus the reason for R11 (10M ) in the inspired by schematic.
« Reply #31 on: April 27, 2018, 08:53:41 pm »
R11 (10M )
that might be a typo for 1M
Offline Ledzepp007
« Reply #32 on: April 29, 2018, 05:26:05 pm »
OK. Here is another try. Take a gander if you wish.
« Reply #33 on: April 29, 2018, 07:10:32 pm »
10M grid leak resistor for V1B is unbelievable.
« Reply #34 on: April 29, 2018, 08:03:54 pm »
is unbelievable.
I have a bumper sticker that says; "honesty is unbelievable "  :icon_biggrin:
« Reply #35 on: April 29, 2018, 11:28:50 pm »
Now that's believable!  :laugh:
Offline jokn
« Reply #36 on: April 30, 2018, 05:48:21 am »
Observations on the schematic (I did not look at the layout yet, as I think it would be best to work out the kinks on the schematic first, and then do the layout): the coupling cap is on the wrong side of the switch, as pointed out by sluckey in post #21. As drawn it puts DC on the switch and/or the top of the clean ch. gain pot.
Were I building this, I’d probably swap the split anode load for a single 330k with the cap across it, since the signal is not being attenuated there, unlike in the “inspired by” schematic.
The voltage divider formed by the 1M series R and the 10M to ground I’d modify with smaller values, say 47k/470k. The 470k will suffice as grid leak, but the series 47k would be less noisy. How big the effect on noise of the series resistor in that position is could be debated, but I’d at least experiment. Also, you may find that you need to dump more than 1/10 of the signal there to keep things under control. YMMV .
And if any of the experts here think I’m way off base, please let me know... gently ;)
« Reply #37 on: April 30, 2018, 11:12:09 am »
Offline Ledzepp007
« Reply #38 on: May 10, 2018, 07:30:30 pm »
OK, OK, I'll move the coupling cap lol.
New schematic attached.
« Reply #39 on: May 10, 2018, 07:58:32 pm »
'Bout time!  :icon_biggrin:
Offline Ledzepp007
« Reply #40 on: May 10, 2018, 08:00:23 pm »
Anything else look like it will blow up and kill me?
« Reply #41 on: May 10, 2018, 08:13:07 pm »
Probably not lethal to you but certainly gonna kill those 6V6s. Look at the bias circuit.
Offline Ledzepp007
« Reply #42 on: May 11, 2018, 08:13:05 am »
Christ the 6V6 cathodes should be grounded and not attached to the bias voltage. Derp
« Reply #43 on: May 11, 2018, 08:25:33 am »
And one other issue that I've narrowed down to this snip for you to find:
« Reply #44 on: May 11, 2018, 09:06:34 am »
hint
Offline davidwpack
    • My music on reverbnation
« Reply #45 on: May 11, 2018, 10:24:52 am »
Mustache is causing static electricity?
« Reply #46 on: May 11, 2018, 11:16:18 am »
depression and ropes make strange bedfellows ?   :icon_biggrin:
Offline davidwpack
« Reply #47 on: May 11, 2018, 01:40:10 pm »
 :laugh:
Offline mwelch55
« Reply #48 on: May 11, 2018, 02:22:39 pm »
Looking at the schematic, I noticed that the power transformer is rated at 275-0-275 @ 100ma.  Is that enough current?  I thought 6V6 push-pull at that voltage would be a little higher, like 120ma.
Mike
Offline Ledzepp007
« Reply #49 on: May 16, 2018, 06:01:36 pm »
Thanks for the feedback. New schem and layout attached. Some small changes. Decided to do a separate bias board and just reverted back to the original Princeton Reverb bias circuit.
