September 14, 2026, 08:12:15 am
Hoffman Amps Forum image Author Topic: Help w/ Marshall Major bias  (Read 5757 times)
Offline Jonas
« on: April 15, 2018, 07:15:45 pm »
Hi, I am working on a Marshall Major build with (2) KT-120's.  I am having trouble figuring out the bias circuit. I did some research and it sounds like the original Marshall Major's had a center tap on the bias winding.  Some schematics floating around on the internet are difficult to read, and may have a few errors on them.  I do not have a center tap on my bias winding.
I am looking for someone to recommend / share a schematic for a bias circuit compatible with a Marshall Major.
Any help would be appreciated, and Thanks!!!
Jonas
Re: Help w/ Marshall Major bias
« Reply #1 on: April 15, 2018, 08:26:30 pm »
What power transformer are you using?
Please post any specs you have.
Are you building an exact Major but just subbing in KT120s?..what schematic are you working off of?
Offline Jonas
« Reply #2 on: April 15, 2018, 09:28:33 pm »
Hi Silvergun.  Thanks for chiming in.  This is not an exact copy of Marshall Major, but I am using a mercury magnetics MP100-67 power transformer.  The PT secondary spec's are  197-0-197; 6.3V @ 7A; 90V bias (two wire) no center tap.
The amp uses a voltage doubler at the first filter stage exactly like the Marshall Major schematic shows.  I'm having issues with turn on due to the high voltages, and I cannot seam to find a bias point that works well with the KT-120's.  How do you trouble shoot a bias supply?  Can I pull the output tubes to trouble shoot the bias supply? What is a good range of negative voltage to check for? -50 to -100?
Jonas
« Reply #3 on: April 15, 2018, 10:23:25 pm »
Jonas
use a FWB for the neg. bias supply. alternatively use a 1/2 wave and ground one side of the bias secondary.
see attached for schema.
« Reply #4 on: April 16, 2018, 07:47:38 am »
Yes, you can work on the bias supply without the tubes installed, in fact it is a good practice to make sure you have the adequate bias voltage before installing the tubes to begin.
The appropriate range depends on what your actual B+ voltage is.
« Reply #5 on: April 16, 2018, 08:31:37 am »
If you wind up with a FWB and you want to use a pot for adjustment:
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #6 on: April 16, 2018, 02:01:04 pm »
So the B+ might wind up around 520V and you might want a bias voltage of -65V with KT120's.  If so, the attached could be a good starting point for a bias circuit.
Offline Jonas
« Reply #7 on: April 16, 2018, 03:01:31 pm »
Thanks everyone! I will give it a try over the next few days (hopefully......) and re-post
