September 08, 2026, 11:39:11 pm
Hoffman Amps Forum image Author Topic: Attenuator with Holland Gibb Droll  (Read 6818 times)
Offline Alleycat
« on: April 17, 2018, 07:12:52 pm »
New here so sorry if this is not the place but figured someone may know. I have a Holland Gibb Droll 4x10 (50W) that has a separate speaker/tube for reverb. It is a hot rodded B59 Bassman circuit from what I understand. Out of the amp are (3) 8 ohm speakers wired in Parallel via 1/4" jack. If my math is right this would be 2.67ohm? There is a RCA jack also coming out of the amp and through reverb unit that goes to a dedicated speaker. I am not a huge fan of the reverb unit so losing it and having a 3x10 cab wouldnt make much of a difference to me and usually run it this way with a delay pedal anyways. Amp sounds INCREDIBLE at 5+ with channels jumped but is VERY LOUD. Would like to add attenuator such as a hot plate but have been leery. I would think that a 2 ohm attenuator with it left as is would not cut the dedicated reverb speaker? Not an amp guy and would love some thoughts before i purchase a 2.67 ohm hot plate and be thinking wrong. Thanks for any help!
Re: Attenuator with Holland Gibb Droll
« Reply #1 on: April 17, 2018, 07:33:24 pm »
Show us a schematic
Offline Alleycat
« Reply #2 on: April 17, 2018, 07:40:03 pm »
I have searched everywhere for one. Oddball amp. Everything I have read says it is a 59 Bassman circuit but I have not found a Bassman with dedicated reverb speaker. Pretty sure this was a Holland thing. Company is no longer around and very little info out there on them except they sound good.
Offline Alleycat
« Reply #3 on: April 17, 2018, 08:01:51 pm »
Basically looks like this in cab. Not sure whats happening inside...
Offline Alleycat
« Reply #4 on: April 17, 2018, 08:18:41 pm »
Looks like the only place I can put an attenuator is at the 1/4" jack to the (3) 8 ohm speakers. In doing so seems like it would only attenuate the load to those 3 speakers and the reverb speaker would be playing on whatever the amp is set at (un-attenuated) If I disconnect the reverb RCA jack at the amp and just use the attenuator at that location this should be 2.67 ohms?
Offline Alleycat
« Reply #5 on: April 18, 2018, 02:04:34 pm »
Got my answer direct from Mike Holland today. Very helpful and full of info. He said the way the circuit is designed a 2.67 hot plate works great with or without the reverb circuit plugged in.
