September 08, 2026, 03:49:18 pm
Hoffman Amps Forum image Author Topic: OT wire colors            (Read 5534 times)
Offline Geezer
OT wire colors
« on: June 18, 2005, 05:18:09 am »
        > OT wire colors
<< Prev Topic | Next Topic >>
Author  Comment
Leevi
Junior tube assistant
(3/12/04 9:23 am)
 OT wire colors
 Are there any standards for the wire colors used in OT:s
I own an OT (a brand new AC30 OT clone) made by Dagnall Electronics (UK?). There are red, white and red wires on the primary side and black, blue and green on the secondary side. I think I'm quite sure of the primary wiring but how to determine the secondary side? So far I have not get any answer from the manufacturer.
/Leevi
Tiny Daddy
I will work on all amps
(3/12/04 10:00 am)
 Re: OT wire colors
 Those wires can be any color.
gammelnalle
(3/12/04 12:31 pm)
 Re: OT wire colors
 what is the problem ? you seem to be a VERY good amp-builder so I guess you have some meters.
The seconddary should be 4 AND 8 ohm so the lowest reading ought to be the 4ohm...
Tiny Daddy
(3/12/04 12:40 pm)
 Re: OT wire colors
 You could put a few volts AC on the secondary and measure voltage on the other leads to determine turns ratio.
6G6
(3/12/04 12:51 pm)
 Re: OT wire colors
 What Tiny Daddy said.
The 6.3V heater taps work well for that.
Leevi
(3/12/04 1:51 pm)
 OT colors
 Thank you for the tips. The problem with measuring the DC resistance on the secondary is that my voltage meter doesn't show any difference between the black, blue and green wires. I think the only way to solve that is to put AC on the primary and measure the ratio as you proposed.
/Leevi
Rotting27
(3/14/04 10:12 pm)
 Re:
 Of course some transformer widners can get nuts, but it seems evident that on the primary side that the reds go to the plates, and white is the CT.
On the secondaries, measure the DC resistance between all the leads two at a time. You will notice that there is a larger resistance between a certain two than any other two. One of those goes to ground, the other is your higher impedence tap. It doesn't matter which you use for ground and which is used for the high impedence tap. I'm guessing that you could go black to ground green to the jack or the other way around. Like I said, either way will be work just the same in an AC30 circuit.
 Topic Commands
Powered By ezboard® Ver. 7.32
