September 08, 2026, 01:58:05 pm
Hoffman Amps Forum image Author Topic: LM317T math  (Read 10222 times)
LM317T math
« on: April 22, 2018, 06:28:00 pm »
I'm trying to model this formula in excel, but I'm unsure of the last part of the formula
for context, here's the link;
http://www.circuitstoday.com/few-lm317-voltage-regulator-circuits
the formula;
(I adj * R2)  doe's it Mean current through Pin 1, (adj), I get the R2 part  :laugh:
If it is current, wouldn't that vary, then varying Vout  :dontknow:
Offline 2deaf
  • Now too deaf for 100 watts
Re: LM317T math
« Reply #1 on: April 22, 2018, 10:23:13 pm »
One of the things that may be confusing you is that Circuits Today got the equation wrong.
IADJ is an unwanted and annoying current through Pin 1 that fools with the voltage drop across the variable resistor and, therefore, the output voltage.  Fortunately, they have reduced that current to 50uA typically with a very small variation across the operating range so that you can practically ignore it.
Re: LM317T math
« Reply #2 on: April 23, 2018, 12:56:18 am »
There's a minimum load current to keep the '317 alive; it can be as much as 10mA.
It is *very convenient* to set the R1 R2 network to suck that 10mA so it gives the right output even when the load is absent.
The reference is 1.25V. 1.25V/10mA is 125 Ohms. (120 is about as good, and a Standard Value.)
Now you do NOT have to think about any silly 50uA stray current at the Adj pin. Less than 2% error when Vref is +/-4% and there's little justification for <5% resistors.
1.25V (1 + (R2/R1)) is the answer.
-OR- (Vout-1.25V) is the voltage across R2. Figure 10mA in that, done.
Offline 2deaf
Re: LM317T math
« Reply #3 on: April 23, 2018, 09:53:28 am »
The correct equation for the diagram shown in Circuits Today is:  1.25V(1+(R1/R2)) + IADJ(R1)
Re: LM317T math
« Reply #4 on: April 23, 2018, 10:08:51 am »
Thank you Sir's, I did finally find "normally ignored" on the data sheet.
I want to use fixed R values, so just plug in #'s till I get 30Vout.
one value I didn't find Max Vin, found differential in/out, max out, I'll look again with fresh eyes
Re: LM317T math
« Reply #5 on: April 23, 2018, 10:27:01 am »
It seems reasonable to me that max Vin would be max Vout plus differential in/out.
Re: LM317T math
« Reply #6 on: April 23, 2018, 11:08:45 am »
Yes; but note that at Turn-On, Vout is *zero* until the output cap charges. This hidden hurt has led a lot of folks into trouble.
Re: LM317T math
« Reply #7 on: April 23, 2018, 04:48:57 pm »
my middle name  :icon_biggrin:
the input is ~40ish bridge rec, filtered DC, the output "load", no power, is ~ 3k ohmed to ground, so I think I'm good to go once I get R1/R2 sorted.  I'm just making a temp supply til I can sort out the original.  I'll fire it up with a DL before I introduce it to the system, just to be sure.
again, thanks for the help
dave
Re: LM317T math
« Reply #8 on: April 23, 2018, 05:17:27 pm »
here's my calculator fwiw  :laugh:
Offline 2deaf
Re: LM317T math
« Reply #9 on: April 23, 2018, 06:10:09 pm »
I can't open that file, but did you get 2.747K with a 120r reference resistor or 5.468K with a 240r reference resistor?
Re: LM317T math
« Reply #10 on: April 23, 2018, 07:24:04 pm »
It's ancient XL  :icon_biggrin:
um, no, I got 2.2k / 120 = 29vdc, went with stock r's, and 29 is close enough to 30 for this.
there's my math;
V0 = Vref * (1 + R2 / R1)
I used 1.5 for vref  :think1: :cussing:
OK, ya, that's what I got  :icon_biggrin:
thanks for the debug  :laugh:
Re: LM317T math
« Reply #11 on: April 29, 2018, 07:06:27 pm »
small progress with confusion;
29.7 is good, my spreadsheet doesn't think so   :dontknow:
I just did a quick unloaded test, the original PS was 30vdc .2A
going back n measuring pin 1, and try to lightly load with a 2-3K r and see
EDIT: updated schematic with CORRECT values, getting closer with the spreadsheet
put it under small load and everything was happy so time to hookup original loads n see
« Last Edit: April 30, 2018, 10:11:05 am by shooter »
