September 15, 2026, 08:32:39 am
Hoffman Amps Forum image Author Topic: Bulb Wattage for Lightbulb Limiter  (Read 7641 times)
Offline turtle441
« on: April 22, 2018, 07:35:12 pm »
What’s the recommended wattage for the bulb in a light bulb limiter?  Is there a rule of thumb?  2 x amp wattage or something similar?  About to fire up a 15-18 watter, looking to build a limiter.
Re: Bulb Wattage for Lightbulb Limiter
« Reply #1 on: April 23, 2018, 12:59:29 am »
For smoke test, "bigger than amplifier" will prevent smoke, but may not play OK.
For "nearly working" you want a lamp several times larger than the amplifier.
Note that a "18W" will certainly draw over 60 Watts from the wall. So think lamps like 100W, maybe 200W.
Note that it MUST be Incandescent (or Halogen). CFLs LEDs work very different.
Offline turtle441
« Reply #2 on: April 23, 2018, 09:10:19 am »
Thanks, appreciate it.  Now to find a hardware store that still sells 100W incandescent bulbs...
Offline ArchieTop
« Reply #3 on: August 12, 2018, 05:37:28 am »
For what it’s worth, I was in a nearby Rural King store and they had 200W incandescent bulbs for $1.99. I thought of my dim light bulb setup and grabbed a few.
Offline byoungblood
« Reply #4 on: August 26, 2018, 08:59:22 am »
I use a 200 watt, the lightbulb rules don't apply to high watt bulbs so incandescents are still easy to find.
Just remember your line voltage will drop across the bulb, for checking voltages you'll need to plug directly into the line.
