September 15, 2026, 06:30:42 pm
Hoffman Amps Forum image Author Topic: 5D3 with tremolo  (Read 5162 times)
Offline Leevi
    • Rikstone
5D3 with tremolo
« on: May 06, 2018, 10:29:37 am »
I have been adding a Vibrochamp type cathode tremolo to a 5D3 circuit and after several tries the best point
seems to be the PI cathode.
http://el34world.com/charts/Schematics/files/fender/Fender_deluxe_5d3_schem.pdf
http://el34world.com/charts/Schematics/files/fender/Fender_Vibrochamp-AA764-schematic.pdf
Since the voltage raises on the cathode too high on full intensity the tremolo signal will dampen quite heavily.
I have balanced the situation by decreasing the 1.5K PI cathode resistor to 1K.
Do you think this will cause some bad consequences sound wise?
/Leevi
Offline 66Strat
Re: 5D3 with tremolo
« Reply #1 on: May 06, 2018, 01:31:34 pm »
IMO, the best option would to adapt the 5E9A tremolo to the 5D3 circuit.
http://thevintagesound.com/ffg/schem/tremolux_5e9-a_schem.gif
You might try tying the PI cathodes togther and use a common 750 to 820 ohm bias resistor. Interject the LFO signal to the joined cathodes.
Regards,
JT
Offline Leevi
    • Rikstone
« Reply #2 on: May 06, 2018, 02:49:22 pm »
I don't see a big difference between Vibrochamp and 5E9-a tremolo.
Furthermore I have made some changes in the tremolo circuit in order to prevent thumping.
Might be worth to try
/Leevi
« Reply #3 on: May 08, 2018, 10:42:33 am »
How did you find the result?
Offline Leevi
    • Rikstone
« Reply #4 on: May 09, 2018, 03:37:48 am »
~OK, maybe not the strongest one but a useful tremolo. I had to tune the intensity down in order to prevent thumping.
A  22n  cap from the plate of the tremolo tube to its cathode eliminated the rest of the thumping.
/Leevi
