September 17, 2026, 09:24:34 am
Hoffman Amps Forum image Author Topic: Hot Rod Deville question  (Read 4728 times)
« on: May 18, 2018, 06:31:56 am »
Looking at the schematic, how did they manage to squeeze 60 watts out of 2 6L6's? I didn't look too closely because it was giving me a migraine  :icon_biggrin:  Is there some SS output "help" there as well?
Online sluckey
Re: Hot Rod Deville question
« Reply #1 on: May 18, 2018, 06:57:28 am »
You posted the wrong schematic in that other thread. This is the correct schematic...
     http://el34world.com/charts/Schematics/files/Fender/Fender_hotrod_deville.pdf
Plate is 485. Those 6L6s must be on the edge of screaming! Look at the note about output test just below the OT...
21.1V RMS into 8Ω load at 5% THD... 21.12/8=55.65W
« Reply #2 on: May 18, 2018, 12:43:31 pm »
G.E. data shows pair of 6L6 making 55 Watts at 2% THD. Last graph shows 70Watts at 7% THD.
« Last Edit: May 18, 2018, 12:46:44 pm by PRR »
« Reply #3 on: May 18, 2018, 07:41:54 pm »
Phew.
Well, I'm not surprised to be surprised. I just recently truly "got" how to calculate center bias to get the most clean from preamp tubes. Of course now it seems dead simple.  Figuring loadlines on pentodes/power tubes still has me flummoxed. Most of my "circuit design" is plagiarism.... err, using other people's research. And trial and error.
« Reply #4 on: May 19, 2018, 08:54:41 am »
If you notice, the point PRR refers is at the very end of the "line" after that the tube vaporizes, somewhere in the middle works fine  :icon_biggrin:
« Reply #5 on: May 19, 2018, 10:22:39 am »
No. Look at the Dissipation line. Pdiss falls from 27W at idle to 18W at "70W out". We are doing great violence to the sound, but the tubes are running happy.
« Reply #6 on: May 19, 2018, 11:37:18 am »
Pdiss falls
I did notice that, I figured it was a last gasp  :laugh:
I'm not sure I ever got a driver tube to put out >75vac before, I know I hit >50
I also know I probably wouldn't like the music   :icon_biggrin:
