September 17, 2026, 11:33:17 am
Hoffman Amps Forum image Author Topic: Turret Minimum Spacing  (Read 5576 times)
Offline Papa Jim
« on: May 19, 2018, 07:55:33 pm »
When building a typical turret board for a tube amp with 500Vdc possible between turrets, what is a safe spacing between adjacent surface edge of turrets.
Re: Turret Minimum Spacing
« Reply #1 on: May 19, 2018, 08:19:43 pm »
I typically use 5/16" center to center spacing for Hoffman's turrets.
« Reply #2 on: May 19, 2018, 09:29:49 pm »
500V won't jump a sheet of paper.
Space to wrap wires without touching may be the practical limit.
But how many 500V nodes do you really have? Typically just a few. Be generous there.
Ask yourself what you hope to gain by violating a reasonable 5/16 spacing. I found that while resistors could be spaced closer, just a few caps makes even 5/16 tight.
Do not build stuff so tight that it can't be modified or repaired!!  I have been sorry too often.
Offline Papa Jim
« Reply #3 on: May 20, 2018, 06:14:57 am »
Thanks guys for the advice.
« Reply #4 on: May 20, 2018, 06:49:04 am »
I did this AC-15 board with 1/4" spacing so the board would be short enough to fit my chassis. 1/4" is tough to work with though. I still recommend 5/16" unless you have a special need.
