September 17, 2026, 02:06:25 pm
Hoffman Amps Forum image Author Topic: Deluxe reverb AB763 blocking distortion  (Read 4875 times)
Offline Leevi
    • Rikstone
« on: May 24, 2018, 01:54:43 pm »
I have built several AB763 but never met this before.
http://tubeamplifierparts.com/schematics/fender_deluxe_reverb_ab763_schematic.gif
I this circuit there is only vibrato channel and PPIMV master isolated with caps.
The problem exists on the second triode of 7025 (12AX7) just before PI.
If I turn preamp volume more than 6 the overdriven signal starts to break and sounds like a blocking distortion.
It helps if I drop the signal level with resistors before 3.3M resistor + cap.
/Leevi
Offline Leevi
    • Rikstone
Re: Deluxe reverb AB763 blocking distortion
« Reply #1 on: May 24, 2018, 11:52:51 pm »
I found the cause.
It was a wiring problem, two wires were too close to each other which caused the problem.
/Leevi
