September 17, 2026, 07:15:40 pm
Hoffman Amps Forum image Author Topic: CJ11 clone build  (Read 6455 times)
Offline Guy77
CJ11 clone build
« on: May 25, 2018, 07:39:11 am »
Hi everyone,  I am fairly new to this forum and have not posted much ( I hang out at ampgarage) but I have learned a lot and wanted to give back a bit.   I was contemplating weather to build a hoSo56 or a Cj11 style amp a while back and ended up building a CJ11 clone. I built it in a 5e3 chassis. I need to make a proper faceplate.
I made a youtube video with my friend Dave playing guitar.
Here is the video, the only change from the schematic that I made here was that I increased the  first power supply cap from 22uf to 47uf this made  the overdrive tighter and not so loose.   I changed the cathode resistor on V1b from 3.3K to 2.3K , the tone controls sounded less sterile when I lowered this resistor.
I really like the  sound of the amp when the boost switch is kicked in and negative feedback is on, it gets really raunchy sounding!
I also put in a negative feedback switch as seen on Rob Robinettes site for 5e3.
The amp sounds great witch a Strat and also sounds nice with a les paul especially if your using the Busrstbucker Pro pickups with less mids.  Here is the link.  It gets really raunchy sounding at the 3:47 mark! There is no sound editing, its right from the video camera, I have not processed the audio from the sm57 mic yet, its hanging from the cabinet, that should sound better.
I attached a copy of the schematic too.
Cheers
Guy
« Last Edit: May 25, 2018, 08:03:22 am by Guy77 »
Re: CJ11 clone build
« Reply #1 on: May 25, 2018, 07:55:33 am »
Nice sounding amp.
« Reply #2 on: May 25, 2018, 03:36:13 pm »
Thanks for sharing your success!  Looks and sounds great.
Offline Guy77
« Reply #3 on: May 25, 2018, 05:46:46 pm »
Thank you everyone.  My friend Dave is a big help on making amps sound good !
I was amazed at how little changes  in  V1b cathode resistor effected the overall sound of the Treble Bass controls.
From more sterile with larger resister to more organic sounding with a smaller resister.
Cheers
Guy
Offline Backwoods Joe
« Reply #4 on: May 26, 2018, 09:51:44 am »
Great build! Sounds awesome. Dave sounds good too. What speaker are you using?
« Last Edit: May 26, 2018, 09:56:17 am by Backwoods Joe »
Offline Guy77
« Reply #5 on: May 27, 2018, 11:10:43 am »
Thanks Joe. The speaker I used here is a Celestion G1265.  The original CJ 11 amp came with a 25 watt Greenback .  I need to try it with a Greenback in the near future to here the difference.
Cheers
Guy
