September 17, 2026, 05:17:39 pm
Hoffman Amps Forum image Author Topic: Need an amp recomendation  (Read 10841 times)
Offline pbman1953
« on: May 25, 2018, 05:57:20 pm »
I know this may be the wrong forum subject for this area, but I wanted to ask guy that know.
I know someone that wants to buy a SS head or an SS head with a tube pre-amp.
She hosts jams and wants something reliable> She needs a 8 ohm rating because the speaker is a JBL E series 140 in a Cabaret cabinet.
Her budget is from $200- $350, max of 400
Re: Need an amp recomendation
« Reply #1 on: May 25, 2018, 06:25:15 pm »
Old black Peavey. Speaker impedance not a factor with ss amps. They usually just have a MINIMUM impedance specification.
Offline pbman1953
« Reply #2 on: May 26, 2018, 07:16:52 am »
When you say old, what years? I don't know Peavey that well.
Thanks for helping!
« Reply #3 on: May 26, 2018, 07:46:37 am »
'70s
Offline 66Strat
« Reply #4 on: May 26, 2018, 11:49:59 am »
Lab Series L5 Guitar Combo Amp. Not a head, but it requires an 8 ohm minimum speaker load. The amp has an 8 ohm speaker jack that the two 12 speakers are plugged into. The JBL cab could be plugged in place instead of the two twelves. Really great sounding amp.
https://www.guitarcenter.com/Used/In-Store-Vintage/Vintage-Vintage-1980s-Lab-Series-L5-Guitar-Combo-Amp.gc?cntry=us&source=4WWRWXGP&gclid=EAIaIQobChMIzfTMmeCj2wIVQxuBCh0C4grGEAQYAiABEgKsnfD_BwE&kwid=productads-adid^221074893837-device^c-plaid^359652442545-sku^114236596@ADL4GC-adType^PLA
https://www.youtube.com/watch?v=JzR54nKKtJQ
Regards,
JT
Offline pbman1953
« Reply #5 on: May 27, 2018, 07:10:26 am »
I should of mentioned that she needs a Bass head.
« Reply #6 on: May 27, 2018, 08:42:43 am »
Yeah, that's pretty important.
« Reply #7 on: May 27, 2018, 09:47:51 am »
Yes, that helps.  I would consider something like this:  https://www.parts-express.com/peavey-minimax-500w-mini-bass-amp-head-with-pre-post-di-out-and-tuner--248-9544
It seems your jam leader wants something simple, and dependable that will be accepted by the musicians. Older eq is past its useful life & will be out of warranty.  At jams, to my dismay, the players go for the newer amps & shy away from vintage eq no matter how venerable it is.
Offline pbman1953
« Reply #8 on: May 28, 2018, 07:18:24 am »
Offline pbman1953
Offline pbman1953
« Reply #11 on: May 28, 2018, 08:55:40 am »
130 watts at 4 ohm.
Please explain how this will be enough at 8 ohm? Plus with a full band.
« Reply #12 on: May 28, 2018, 09:19:17 am »
130W @ 4Ω would be 65W @ 8Ω. That's enough to blow the paper out of that JBL. But you never specified a power rating 'til now. Why don't you give us all your specifications at one time rather than dribble out one clue at a time? Or better yet, go talk to the knowledgeable people down at Guitar Center. Shouldn't take more than 15 minutes to find your perfect amp if you write down all your specs and expectations. Take your friend so she can test drive.
Offline dude
« Reply #13 on: May 28, 2018, 09:40:57 am »
Best solid state amp I ever heard is the old Acoustic amps, late seventies early eighties. They're not cheap if you can find them, they sound like a tube amp and very reliable. Not talking about an "acoustic guitar amp" but these were made for electric guitar.
https://www.ebay.com/itm/Vintage-Acoustic-Guitar-Amplifier-Model-G60-212/152855084110?hash=item2396df7c4e:g:9vcAAOSwObhaUBiM
Offline pbman1953
« Reply #14 on: May 28, 2018, 10:21:37 am »
Ok Here's what you need .I was assuming maybe you'd know the series-
http://www.jblproservice.com/pdf/Cabaret%20Series/4621A.pdf
 I was totally off. I thought it was a E140, but in reality its a E130, better suited for keys or guitar, I think. But, she likes it and she owns it now.
« Last Edit: May 28, 2018, 10:28:21 am by pbman1953 »
« Reply #15 on: May 28, 2018, 10:35:15 am »
Wow! That's an awesome speaker... But it ain't suited for a bass rig.
« Last Edit: May 29, 2018, 11:29:14 am by sluckey »
« Reply #16 on: May 28, 2018, 11:01:37 am »
I have a pair of these if she wants more power  :icon_biggrin:
http://www.jblproservice.com/pdf/Discrete%20Sales%20Models/2035HPL.pdf
« Reply #17 on: May 28, 2018, 08:13:55 pm »
Manual says E-140.
I have done LARGE concerts in the park with a few E-130. You don't need, and don't really want, megapower. The E-140 is stronger below 100Hz and "weaker" above 100Hz, but still a LOUDspeaker, and perfectly tuned for bass.
These speakers (in D- model) were once rated at 25W, then 75W. While newer glues and test-specs give 400W ratings, 75 Watts is really enough for almost anything. Especially indoors, in a crowd that does not justify >$350.
The E-130 used as a bass instrument amp will get slappy with much past 75W. It gave up excursion to get more coil IN the gap and more midband efficiency.
Offline pbman1953
« Reply #18 on: May 28, 2018, 08:20:34 pm »
Manual says E-140.
Great info, so do you have a SS amp head suggestion?
« Reply #19 on: May 28, 2018, 08:38:59 pm »
I liked 150W Bogen tube amps, two E-130 on each channel (75W per speaker). Maybe 1/ch (150W) for bluegrass (low bass).
But that's not something to even wish for today.
Offline pbman1953
« Reply #20 on: May 28, 2018, 08:41:37 pm »
There's only 1 cab- a single e140
Offline pbman1953
« Reply #21 on: May 29, 2018, 08:05:07 am »
Also , I'd love nothing but tube but I think the desire is SS to be maintenance free.
Any other suggestions?
« Reply #22 on: May 29, 2018, 10:04:20 am »
Ditto.  At this point I'm totally confused.  I have no idea what speaker we're trying to drive; or if it's suitable for bass.
The pdf you quote says 140-8; but your words say E130.  Que passa?
Offline pbman1953
« Reply #23 on: May 29, 2018, 10:10:13 am »
I did an edit but didn't change the post to show the correct spec sheet.
Here's the proper JBL spec sheet-
It's an E130 @ 8 ohm. It should be fine but not optimum for bass. The 140 series was better suited for bass but she's staying with the 130.
« Reply #24 on: May 29, 2018, 11:00:39 am »
Ok!  It will do in a pinch. I stand by my earlier Peavey SS amp recommendation, or something cheaper but similar.  See:  https://www.google.com/search?q=100w+bass+amp+head&oq=100w+bass+amp+head&aqs=chrome..69i57.4070j0j8&sourceid=chrome&ie=UTF-8
But:  it's good for 300W but down only to 50Hz.  IMHO this is really inadequate for bass.  You really want down to 40 Hz, maybe lower for subharmonics.
There's plenty of solid state bass combo's that are cheaper than heads, and presumably have more appropriate frequency response.
See: https://www.google.com/search?q=100w+bass+amp&oq=100w+bass+amp&aqs=chrome..69i57j0l5.3334j0j8&sourceid=chrome&ie=UTF-8
