September 17, 2026, 02:06:25 pm
Hoffman Amps Forum image Author Topic: Help with output transformer wiring  (Read 9601 times)
Offline Joe6v6
  • Kill Ugly Radio !
« on: May 26, 2018, 08:21:48 pm »
Im using the transformers from the attached schematic for a 4xEL34 build, I am unfamilure with the way this output transformer is wired. What is the orange (ORN) wire at the top of the output side? Is it a 16 ohm tap that is used for some sort of negative feedback or something else? What should I do with it in the same type setup as a 100 watt marshall?   Thanks  : Joe
Tubeaholics dont want recovery they want tone!
Offline 92Volts
Re: Help with output transformer wiring
« Reply #1 on: May 28, 2018, 12:28:18 pm »
It is used for feedback, but doesn't drive a speaker. There's no way to know if it can supply enough current to drive a 16 ohm speaker (probably not) or if the level is equal to a 16 ohm speaker tap. I would leave it unconnected and use the red (8 ohm) or brown (4 ohm) wires for feedback.
There are still 2 wires shown without the colors labeled-- the common/ground on the secondary side and the center tap on the primary/tube side. You can check with an ohmmeter which winding an unknown wire is part of, and they're hopefully bundled with or located near the other primary/secondary wires.
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #2 on: May 28, 2018, 01:39:15 pm »
What are the turns ratios for this transformer?
Offline Joe6v6
  • Kill Ugly Radio !
« Reply #3 on: May 28, 2018, 10:30:12 pm »
This is what I was thinking, best to just leave it disconnected. I can live with just 4 & 8 ohm.
Ive got this part figured out, Black on the secondary & red & white on the primary, I wont be using the ultraliner taps.
Is there a way to determine this? I have no idea.
         Thanks for the help : Joe
Offline 2deaf
« Reply #4 on: May 28, 2018, 11:42:20 pm »
You basically put an AC signal into one side and see what comes out the other side.  I don't know what equipment you are armed with, but the tests can apparently be done with a 6.3V AC signal and a voltmeter.
I'm betting that the mystery tap is 16r just like a zillion other transformers.
Now that you mentioned UL, I think I know how the switching should go for triode/UL modes.  The drawing has the switch drawn wrong.
« Reply #5 on: May 29, 2018, 05:44:33 am »
also missing is the Base drive for 2N4401 for channel switch indicator.
how it should be wired for UL switching - see attached.
Offline 2deaf
« Reply #6 on: May 29, 2018, 09:38:58 am »
Attached is what I thought they were trying for:
Offline 92Volts
« Reply #7 on: May 29, 2018, 01:52:31 pm »
Yes-- keep in mind, the winding (voltage) ratio is the square root of the impedance ratio. So a 16-ohm tap outputs 2x greater voltage as an 4-ohm tap. If you apply 6.3v AC to a 4 ohm tap you'd expect to see 12.6v from a 16 ohm tap.
This produces a larger voltage on the primary side, remember this for safety and to not kill the OPT.
The voltage ratio between 2000 and 4 ohms is sqrt(2000/4)=22.4, so 6.3v is scaled up to 140v or so on the primary of a 2k transformer. That's pretty normal/safe for a tube amp. Do NOT apply 120v to the 4 ohm tap, as this "wants" to create thousands of volts on the primary but will likely destroy things first.
It's definitely wrong, it shorts the UL taps to the plates as-shown. The right wires are there, but the switches are "rotated".
Offline Joe6v6
  • Kill Ugly Radio !
« Reply #8 on: May 29, 2018, 03:53:13 pm »
I applied 6.3v to the primary side - center tap & blue wire , on the secondary side there is .4v brown, .6v red , .85v orange. So with the orange wire being a little more than twice the brown (4ohm tap) it makes sense that this is a 16 ohm tap, correct?
Offline 2deaf
« Reply #9 on: May 29, 2018, 04:07:31 pm »
The results are consistent with a 2000 Ohm primary and a 4, 8, 16r secondary.
