September 17, 2026, 09:32:32 pm
Hoffman Amps Forum image Author Topic: Crossline MV - Is it necessary to add two further coupling caps ???  (Read 5848 times)
A friend today asked me how to add a crossline MV to an amp that has fixed bias and the firtst thing that come to my mind was to put two
additional coupling caps between the pot and the 220k resistors, but later I've think again to this thing and ....
is it really necessary to add those caps ? (on the red square)
p.s.: The schematic is only an example
« Last Edit: June 04, 2018, 03:22:37 pm by kagliostro »
Re: Crossline MV - Is it necessary to add two further coupling caps ???
« Reply #1 on: June 04, 2018, 04:50:23 pm »
no
« Reply #2 on: June 04, 2018, 04:51:20 pm »
Thanks Steve
Offline leroy
« Reply #3 on: June 06, 2018, 09:10:44 pm »
Aren't the second caps there to stop the bias being shorted to ground?
Leroy
« Reply #4 on: June 06, 2018, 09:47:27 pm »
Nothing about that crossline MV is connected to ground.
Offline OrganicEffects
« Reply #5 on: June 09, 2018, 10:24:46 am »
I believe those caps are present in the MV that AllenAmps mods Fender amps with?
« Reply #6 on: June 09, 2018, 10:41:21 am »
The caps are on some of the Allen amps, but not all. Regardless, Allen uses a completely different dual pot MV, not a crossline MV like being discussed in this thread. So, not applicable.
« Reply #7 on: June 12, 2018, 07:00:06 pm »
Ah I see where we got confused. The crossline MV uses out of phase signals to cancel each other out and reduce the volume?
Looks like the version I was thinking of using a dual pot with either end to ground.
