September 17, 2026, 12:38:38 am
Hoffman Amps Forum image Author Topic: Brownface PT question  (Read 7006 times)
Offline alange5
« on: July 07, 2018, 01:17:57 pm »
I'd like to build something based on some of the Fender brown circuits - a cross between the 6G11 Vibrolux and the 6G5 Pro.
I'd like to incorporate the bias-vary tremolo of the 6G11 with the diode rectification and higher voltages of the 6G5.
The 6G5 calls for about 450V on the 5881 plates.  I have two PT options in mind:
Classictone 40-18005
http://www.classictone.net/40-18005.pdf
330-0-330 @ 240ma w/ 50V bias
Classictone 40-18041
http://www.classictone.net/40-18041.pdf
325-0-325 @ 180ma w/ 50V bias and 5v windings
If I opt for the 325V PT, will I be ok with the 180ma current (2x6L6 or 2x5881), and could I simply tie off the unused 5v windings?
Re: Brownface PT question
« Reply #1 on: July 07, 2018, 01:59:00 pm »
yes, yes
Offline alange5
« Reply #2 on: July 07, 2018, 03:45:56 pm »
Thanks.
Here's the schematic I'll be working with:
brown_amp" border="0
Any glaring problems?  Does the coupling before the PI look ok? (plate > 100k > .05 > grid)
« Reply #3 on: July 07, 2018, 04:47:25 pm »
Each preamp triode needs a 1.5K||25µF between the cathode and ground. Also, connect the .05µF coupling cap directly to the plate of the second preamp triode and remove the 6.8K, connecting point A directly to the 100K.
Offline alange5
« Reply #4 on: July 08, 2018, 01:32:31 pm »
Thanks for the reply.
Here's the updated schematic with the "A" version of the tone stack (used in both the 6G11-A and the 6G5-A):
brown_amp_copy" border="0
I have an extra cutout for a pot on my chassis.  I'm considering adding a master volume.  If I use the "type 2" master volume where a dual gang pot replaces the power tube grid leak resistors, will the tremolo still work properly?
Here's the Robinette example from a 5F6A:
type_2_mmv" border="0
« Reply #5 on: July 08, 2018, 03:24:59 pm »
Trem should work with that MV. Before you commit to that tonestack you may want to find a source for that odd treble pot. Hoffman used to carry it, but not now.
Offline alange5
« Reply #6 on: July 08, 2018, 03:55:43 pm »
Thanks for the help sluckey.
Looks like amprepairparts.com carries those tapped pots.  They have a whole section dedicated to "brown" parts.
« Reply #7 on: July 08, 2018, 04:15:28 pm »
Thanks for the link.
