September 17, 2026, 07:21:52 am
Hoffman Amps Forum image Author Topic: Peavey Delta Blues issue  (Read 7570 times)
Offline Leevi
    • Rikstone
« on: July 10, 2018, 10:47:52 am »
I'm trying to fix the reverb of the Peavey Delta Blues combo.
http://el34world.com/charts/Schematics/files/Peavey/Peavey_deltablues.pdf
The output side of the circuit seems to work since the amp reacts pretty well when touching the springs.
I have even tried with another reverb pan without success.
How common is it that the IC with the OP amps is broken? The circuit could be changed quite easily.
Otherwise there is very difficult to do any changes.
/Leevi
Re: Peavey Delta Blues issue
« Reply #1 on: July 10, 2018, 12:13:52 pm »
since the other half is recovery and that works, I'd suspect cables, connectors, no signal getting in, but for $2 you can cut it out, solder in a good socket and a new chip.
got a scope?
Offline Leevi
    • Rikstone
« Reply #2 on: July 10, 2018, 03:09:54 pm »
I measured the tank input with scope and there is no signal visible.
I also measured the cable which is OK. There is about -5V DC voltage at the tank input.
/Leevi
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #3 on: July 10, 2018, 06:41:43 pm »
Ground is the positive rail for that 4558 Op Amp and the signal is referenced to -15V.  You might get some funny results if your testing equipment is referenced to ground.  You also have to make sure that the shield on the reverb input cable never has a path to ground.
Offline Leevi
    • Rikstone
Re: Peavey Delta Blues issue [SOLVED]
« Reply #4 on: July 11, 2018, 09:59:24 am »
I found the cause for the problem. It was probably a bad contact on one IC leg.
After I had measured voltage on the leg the reverb started to work. The IC stays in its socket.
Now also the voltage across the tank input is 0V and the reference voltage towards ground -15V which sounds right.
/Leevi
« Reply #5 on: July 11, 2018, 12:27:43 pm »
when I 1st started fixing CAT scanners, the system I started on was basically an R&D system, everything in the "front-end" was socketed IC's while permanent boards were being made. 90+% of all the problems were fixed by taking the "bad" board out, laying it on a hard surface and pressing down on ALL the IC's, walla, gone fishing  :laugh:
