September 18, 2026, 04:17:01 am
Hoffman Amps Forum image Author Topic: 6GW8 Parallel SE  (Read 10792 times)
6GW8 Parallel SE
« on: July 12, 2018, 05:05:29 am »
Hi guys, Looking at doing something simple.
Questions...
What OT primary am I needing and what power rating.
 :icon_biggrin:
Re: 6GW8 Parallel SE
« Reply #1 on: July 12, 2018, 06:48:37 am »
I like that idea!  You sure come up with some cool stuff!   :thumbsup:
« Reply #2 on: July 12, 2018, 06:55:21 am »
Do you have a stash of 6GW8s? They are kinda pricey over here. About $60 each.
« Reply #3 on: July 12, 2018, 09:14:34 am »
need a 2nd opinion, but looks like ~RA 24k, so 1/2 ~10k-ish, so a 5K using a 4ohm skr on 8ohm tap  :dontknow:
power-wise, a low range would be 15W, go up from there
when I get some time i'll try and hunt down a data sheet
« Reply #4 on: July 12, 2018, 11:06:31 am »
while rooting around the web I found this paper by your neighbor, might help?  It's PP, but PSE specs should be "close enough"
https://dalmura.com.au/static/Australian%206GW8%20PP%20amp.pdf
« Reply #5 on: July 12, 2018, 11:19:23 am »
Yes - the pentodes are rated at 9W. For centre-bias class A, running at (say) 300V:
300/(9/300) = 10,000R.
2 in parallel would be 5k.
As to power rating - figure about 40% of (2 x 9) = 7.2W. 2 or 3 more watts above this would be a good margin of safety ;-)
« Last Edit: July 13, 2018, 05:35:15 pm by tubeswell »
« Reply #6 on: July 12, 2018, 01:46:54 pm »
Thanks guys.
Sluckey, I have a few 6GW8s left, but my supplier has a stack of 14GW8s
He's looking to get some transformers wound to accommodate the 14.5v heaters.
« Reply #7 on: July 14, 2018, 05:27:29 pm »
The reverb will be a work in progress, as the Belton brick is something I want to try.
After rummaging through my discarded builds I was able to find a few bits I could use.
The chassis has been sitting on the shelf for so long I can't remember why I had it bent like that. :dontknow:
WASTE NOT WANT NOT
 :icon_biggrin:
« Reply #8 on: July 18, 2018, 05:55:53 am »
Hi guys, Some progress.....
Just waiting on the OT
« Reply #9 on: July 19, 2018, 04:28:10 am »
 :thumbsup:
« Reply #10 on: July 20, 2018, 03:53:41 am »
Thanks Franco.
Guys I had another think about the heater supply.
I using a 1A transformer that ahs 6.3v and 12.6 taps and I will be adding a 12AX7 to the 6GW8.
Would this be a better circuit.
« Reply #11 on: July 21, 2018, 04:58:12 am »
Hi guys, Tweaked the circuit some and fired up well, sorta.
The back to back transformers under load did not have the expected 300ish output  :crying:
A bit of head scratching and connecting the 18v tap on the first transformer to the 12v tap on the second transformer helped greatly.
Still not quite 300v but good enough.
« Reply #12 on: July 21, 2018, 08:45:10 am »
Timbo,
As always, thanks for sharing your info and schematic!
How does it sound?
with respect, Tubenit
« Reply #13 on: July 21, 2018, 09:31:28 pm »
Thanks T, This little amp sounds like a BIG amp.
Had a muso give it a whirl and I was very impressed.
Plenty sparkle and great bottom end.
Would work well with 6BM8s
« Reply #14 on: August 08, 2018, 05:09:48 am »
Hi guys, After much tinkering I think I've got this one done.
Adding the Belton reverb brick was a bigger job than I thought.
If you like plenty of reverb these bricks are great and sound pretty good.
I need to do some tiding up and I'll get some pics.
If there is anything I should not have done please tell me, as it was very much trial and error addon.
« Reply #15 on: August 09, 2018, 05:08:45 am »
Hi guys, put the finishing touches on the circuit.
Overall I think this one has turned out pretty good.
Does clean to mean very well with great reverb.
Cab is under construction as we speak.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #16 on: August 14, 2018, 09:40:51 pm »
Sound sample pls ?!  :icon_biggrin:
https://soundcloud.com/ukiuki
« Reply #17 on: August 15, 2018, 01:46:51 am »
Will do ASAP.
« Reply #18 on: July 11, 2020, 05:57:37 pm »
Hi guys, The "CHICKABOO 10" is complete.
Will work on some clips soon.
« Reply #19 on: July 11, 2020, 06:41:14 pm »
true craftsmanship!
nicely done
Offline bmccowan
  • Better builder than player
« Reply #20 on: July 11, 2020, 08:49:41 pm »
Super nice! I'll be interested to hear some sound clips. Parallel SE amps have their own charm.
Mac
John Prine
