August 15, 2026, 10:03:40 am
Hoffman Amps Forum image Author Topic: Help with shielding  (Read 4452 times)
Offline dude
Help with shielding
« on: August 04, 2018, 01:42:20 pm »
With a humbucker guitar the amp is dead quite, a strat a lot of hum just with this amp. Single coil strat is shielded, pickguard, pockets, strings and jack input pocket. Almost no matter how far from the amp I get I have hum, a very few spots I stand I "lose it", usually at least 10 feet away at a certain position but just turning a bit, hum back. The hum is almost anywhere within fifteen feet of the amp. Only two pick up selections, neck/middle or bridge/middle the hum goes, middle is probably reversed wound. I play with a blender pot on a tone knob, blending neck and bridge, get a lot of hum.
Any suggestions? I have the amp, a head, totally enclosed with a bottom metal shield, still hum. Could this be lead dress inside the amp, it's a JTM45 clone I built.
OK, just tried another strat, no HUM. It's the guitar, what can I do, it's already shielded. Could it be the blender pot I just installed. I got the wiring diagram from Lindy Fralin.
al
« Last Edit: August 04, 2018, 01:49:35 pm by dude »
Re: Help with shielding
« Reply #1 on: August 04, 2018, 01:50:30 pm »
Not likely. Probably some noisy electrical appliance or lighting. Turn off all nearby lights and appliances. Or take the amp and Strat to a friends house. Same results?
Offline dude
« Reply #2 on: August 04, 2018, 01:52:16 pm »
You missed the added note. It's not the amp but the strat. reread the post for added info.
Also, this same strat with same amp didn't hum with a push/pull pot for the neck and bride. I like the blender pot instead of the push/pull as I can blend the amount of the bridge with the neck.
Must be something in that Lindy layout...?
al
« Last Edit: August 04, 2018, 02:01:39 pm by dude »
« Reply #3 on: August 04, 2018, 02:02:44 pm »
Play the other strat!   :icon_biggrin:
Offline dude
« Reply #4 on: August 04, 2018, 02:53:07 pm »
Ha, ha  :icon_biggrin:  pretty clever! I opened myself up for that  :laugh:
I just noticed that Fralin diagram doesn't have the tone pots grounded...? But the pickguard shield should have covered that, hopefully not, can't hurt to run a ground wire from the volume ground to the tones. Such a hassle to get inside a strat wiring.
I guess if the added ground doesn't work, then go back to the push/pull knob but no blend, my favorite strat too. OH well, sh-t happens.
al
Offline labb
« Reply #5 on: August 04, 2018, 04:22:30 pm »
https://www.ebay.com/itm/25-Tinned-Brass-3-8-Potentiometer-Switch-Grounding-Lugs/191928884664?hash=item2cafda5db8%3Ag%3AGw0AAOSwARZXkjgD&_sacat=0&_nkw=potentiometer+ground+lug&_from=R40&rt=nc&LH_TitleDesc=0
I know nothing about guitar wiring but if I did I would have some of these. Anytime you have to solder to the back of a pot you (me) are looking for trouble.
