September 15, 2026, 02:30:25 am
Hoffman Amps Forum image Author Topic: Bogen CHB 10A's Come alive  (Read 9510 times)
Offline Silvertone
« on: August 16, 2018, 03:02:39 pm »
Re: Bogen CHB 10A's Come alive
« Reply #1 on: August 16, 2018, 04:58:06 pm »
 :thumbsup:
Offline Platefire
« Reply #2 on: August 28, 2018, 08:48:45 pm »
That's what I call CHB10A Heaven with those nice colors and cabs. Fine work there!
Here is my less dressed CHB-10A
On the right track now<><
Offline moapys
  • Old/small/"odd-tube"-chassis => guitar subversion
« Reply #3 on: November 13, 2022, 08:24:13 am »
Old thread resurrection / cross-post alert! Say friends; on this odd Bogen CH10 power supply: I've never seen the filter-cap arrangement as seen on the first stage before (attached)...? In all PS that I've seen, all caps are referenced to ground (e.g. B+ on pos / GND on neg); yet this one has a "stacked" initial R/C filter, with one element of the original can multi-cap in series with an external electrolytic of the same value!
I've just recapped one, to begin a guitar conversion, but - before I bring it up on the variac - was hoping someone could help me understand the intent of injecting the rectified DC BETWEEN a pair of 20uF's (C1 and C2 on the PS schematic). Thanks in advance!
Offline thetragichero
« Reply #4 on: November 13, 2022, 09:16:00 am »
read up on voltage doubler circuits. non-center-tapped ht winding with too low vac for a full wave bridge to provide desired dc voltage so bogen uses a voltage doubler (I've used a voltage tripler/quadrupler on an old organ transformer to get bias voltage before. definitely a good trick to have in the arsenal)
Offline moapys
« Reply #6 on: November 13, 2022, 04:57:30 pm »
Should have re-drawn to recognize topology - 'multipliers are familiar...apparently undercaffeinated.
Amp came up just fine; only some hum/noise to remediate, and a dodgy preamp socket that needs a clean and tighten.  Thx, all.
