September 08, 2026, 05:45:15 pm
Hoffman Amps Forum image Author Topic: DIYLC - DIY Layout Creator install info and download links  (Read 112016 times)
« on: August 30, 2018, 01:04:34 pm »
The DIYLC library is here
https://el34world.com/charts/DiyLayoutCreatorFiles.htm
You can download DIYLC for free and it is free to use
The direct link to the download page
I like to use the win.exe file to install the program
https://github.com/bancika/diy-layout-creator/releases
This board on Github is where you can ask questions
https://github.com/bancika/diy-layout-creator/issues
DIYLC is coded in Java and so it will work on all operating systems that have Java installed
Do not try and install Java from a browser window
See my post further down this page on Java install tips
You do not have to install DIYLC if you do not want to
You can download a .zip file and just start the program by double clicking on the .exe file in the un-zipped folder
Installing the program lets you click on a .diy file and it will open DIYLC program automatically
So it creates file associations if you install it
It's a pretty small program and does not seem to be too bulky or intrusive, so I always use the install download.
Install info from the manual
https://github.com/bancika/diy-layout-creator/blob/wiki/Manual.md
There is a new book on using DIYLC by the author
I will try and get an official web page link to it but for now, I uploaded it here
https://el34world.com/charts/DiyLayoutCreator/files/Misc_Diy_Files/Mastering DIY Layout Creator v1.0 - Preview.pdf
« Last Edit: August 01, 2026, 07:34:28 am by EL34 »
Re: DIYLC - DIY Layout Creator info
« Reply #1 on: August 30, 2018, 01:29:44 pm »
The DIYLC config file holds many of the objects you save, like variants and Building blocks
Look in your documents for the .diylc folder. under your user name
The link to mine in windows 7 pro is this
C:\Users\DLH\.diylc
The DIYLC config file is named config.xml
There is also a logs folder and a logs file is created every time you start DIYLC
The older logs will automatically be deleted by DIYLC after about a week
« Last Edit: February 26, 2019, 08:19:48 am by EL34 »
Re: DIYLC - DIY Layout Creator install info and download links
« Reply #2 on: November 25, 2018, 06:09:37 am »
I'll post solutions to any install problems that people report here
Windows XP - Person reports that they had to download an older version of Java and then DIYLC ran fine
Misc MAC info
I'm trying to download DIYLC on my mac.
after extracting from zip, it says the package is damaged and can't be opened.
I've tried several times. Is there an issue with the mac version?
Try running this in the terminal. sudo spctl --master-disable
Go about half way down this page and look for this text
OSX users: make sure that 3rd party apps are allowed on your Mac before installing DIYLC
Thanks to all, the gatekeeper fix worked. And I learned something! always good
https://www.santoshsrinivas.com/disable-gatekeeper-in-macos-sierra/
Info from Github on OSX installs
OSX says that DIYLC is damaged and cannot start (the absolute greatest hit)It is definitely not damaged, do not give up.
There's a thing in OSX called Gatekeeper that blocks 3rd party apps by default and as a result they appear to be damaged.
It's handled very unfortunately, but it is what it is.
To fix the issue, you just need to allow 3rd party apps.
Different versions of OSX handle this differently and I've seen many different ways to do it, but this should be a good starting point
Files not saving as .diy
https://github.com/bancika/diy-layout-creator/issues/376?
More Mac info
https://oliverdowling.com.au/2014/03/28/java-se-8-on-mac-os-x/
https://oliverdowling.com.au/2015/10/09/oracles-jre-8-on-mac-os-x-el-capitan/
https://github.com/bancika/diy-layout-creator/issues/370#issuecomment-453547136
“DIYLC” is damaged and can’t be opened. You should move it to the Trash."
MAC error message fix - See #3 on this page
« Last Edit: March 09, 2019, 04:21:40 pm by EL34 »
« Reply #3 on: December 03, 2018, 08:45:09 am »
The official channel to report issues with the program is here on GitHub
« Reply #4 on: February 26, 2019, 08:23:50 am »
Chrome will not even let you do it
Look at the screen shot below about this
Go to the Java download page and download the Java version you want to install
Download the install file and install Java from your computer
The Java download page link is here
https://www.java.com/en/download/manual.jsp
I posted a screen shot below showing what the Java download page looks like
In Windows, there is a control panel applet if you have Java installed
You can look at the current version you have installed and modify Java
I posted a screen shot below that shows the control panel access to Java
« Last Edit: February 26, 2019, 08:27:05 am by EL34 »
Browser tries to open a file instead of downloading it
« Reply #5 on: May 11, 2021, 07:51:22 am »
If your browser tries to open a file instead of down loading it, right click on the file link and choose "Save as"
Browsers may call it different things, but look for something like "Save As"
Different browser text for down loading a file
Save Linked Content as
Save Link As
Save Target As
« Reply #6 on: August 09, 2024, 06:57:13 am »
When installing DIYLC, you may run into a windows pop up asking if you really want to install this 3rd party software.
You have to click on the more info link to get a second pop up
You can then click on the Run Anyway button to continue the install
« Reply #8 on: August 01, 2026, 07:33:44 am »
