October 05, 2026, 12:32:09 am
Hoffman Amps Forum image Author Topic: Go ahead and post questions in this board about DIY Layout creator  (Read 53297 times)
Offline bug
testing regular member account to see if they can see this board and post in it
« Last Edit: December 14, 2018, 02:03:15 pm by EL34 »
Re: testing
« Reply #1 on: September 29, 2018, 08:10:41 am »
testing .diy file attachment
Offline pullshocks
Re: Go ahead and post questions in this board about DIY Layout creator
« Reply #2 on: December 14, 2018, 11:17:39 pm »
Doug--
A big THANK You for creating the component templates.  That is going to save a lot of time.
I am experiencing some weirdness when I try to download template files from the library .
If I understand right, the method is to right click the link, and select "save target as"
A few times doing it that way, it gave me the option to save as a DIY file type into the folder where I keep my DIY files.  I got a few of them downloaded into my folder, and they open fine.
But now when I right click and select "save target as" it is only offering me to save as an XML file.  It opens the right folder, but does not give the option to save as a DIY file.
What am I doing wrong.
« Reply #3 on: December 15, 2018, 05:54:41 am »
Doug--
I am not right clicking on the file names
I left click on the files and it offers to save to my local machine
Let me know if that works
If not give me a file name that does not work right
« Last Edit: December 15, 2018, 06:26:03 am by EL34 »
Offline pullshocks
« Reply #4 on: December 15, 2018, 01:21:01 pm »
OK, when I left click on the file, it opens a code version of the file.
What I have now figured out, is that after I left click, open the code version of the file, and close it, THEN, I can right click, select save target as, and it will give me the option to save as a .DIY file.
That workaround only takes a couple seconds, so I can live with that.
For what its worth, I am running Windows 10, and use the Microsoft Edge browser.  I have not tried any other browsers.
Thanks again
Mark
« Reply #5 on: December 15, 2018, 02:31:36 pm »
Hmm, ok
I am using chrome and it works fine
Downloads the file on a left click
Just tested it in IE11
Left click opens the file as xml in a browser window
Right click - Save Target as tries to save as .xml
I had to change the file suffix to .diy and it was fine
Firefox
left click opens a dialog box with two choices - Open with a program or save file
Right click - save link as saves the file as a .diy file
Weird how all the browsers act differently
Offline pullshocks
« Reply #6 on: December 15, 2018, 06:03:01 pm »
Thanks Doug.
I am also having trouble getting the new version installed.  I downloaded the zip file, but I don't know how to install.
« Reply #7 on: December 15, 2018, 06:30:51 pm »
Use the windows installer files, not the zip files
https://github.com/bancika/diy-layout-creator/releases/tag/v3.41.1
Like in the screen shot below
« Reply #8 on: December 16, 2018, 07:31:49 am »
Hi Doug,
I am using Windows 7 Pro still:
1) I right click on your DIY files and it only gives only the option in the drop down menu below file naming as .xml - HOWEVER if one simply names the file and includes ".diy" it will save it as that type of file which then opens properly in the program.
2) I've been waiting a while for Bancika to fix the BOM to Excel issue and I received an email saying it is fixed in version 3.42.0 - however, this version is not available at this time. Only 3.41.1 is available as of now. Not sure if you've noticed or needed this?
« Reply #9 on: December 16, 2018, 07:36:55 am »
Hi Doug,
I replied to your comment on github
he is working on several other things before releasing the next version
I paid him to create a cut line
I think it fired him up again to start working on DIYLC again
« Reply #10 on: December 16, 2018, 07:39:01 am »
Hi Doug,
You can see the info he is posting about the new version on the DIYLC facebook page I created here
https://www.facebook.com/groups/866347656903552/
« Reply #11 on: December 16, 2018, 07:40:21 am »
Hi Doug,
I posted up above about the file download and what happens in different browsers
« Reply #12 on: March 30, 2019, 07:09:37 pm »
any chance your click circles program is still linkable?  I got a good layout and just need a "drill guide".
« Reply #13 on: March 30, 2019, 07:36:33 pm »
The link is at the bottom of all the hoffmanamps.com pages
« Reply #14 on: March 30, 2019, 08:04:56 pm »
you're probably out filling the order now  :laugh:
the "old path" changed, and I'm old  :icon_biggrin:
« Reply #15 on: March 31, 2019, 07:53:49 am »
You add custom boards to your shopping cart in the program
look at my screen shot below
« Last Edit: March 31, 2019, 08:11:30 am by EL34 »
« Reply #16 on: March 31, 2019, 10:24:17 am »
Ya, I clicked it, took me to the store n I started adding things, then I realized no board  :dontknow:, so put in the notes
