September 18, 2026, 02:15:15 am
Hoffman Amps Forum image Author Topic: Silicon on filtercaps?  (Read 4803 times)
Offline Oddvar
« on: September 07, 2018, 07:25:02 am »
Hi.  I was just wondering what to use to really steady the filter caps.  Is it regular silicon or is it some kind of glue?
Re: Silicon on filtercaps?
« Reply #1 on: September 07, 2018, 07:57:02 am »
Silicon is what transistors are made off. Silicone is what you're looking for. Not the grease or lube but the caulk. I've seen both silicone caulk and hot melt glue used for this purpose. I would prefer silicone.
« Reply #2 on: September 07, 2018, 10:04:35 am »
FWIW I also use foam double sided tape.
« Reply #3 on: September 07, 2018, 01:29:47 pm »
Find and use GE silicon II - don't use anything with Acetic Acid in it.
Offline sds1
« Reply #4 on: September 08, 2018, 05:48:42 am »
Yeah make sure it's electronics grade. The stuff you'd get at auto parts stores and elsewhere will offgas corrosive vapors.
Offline Oddvar
« Reply #5 on: September 16, 2018, 10:22:22 am »
Thanks guys, been away for awhile, so haven't had the chance to day thank you.
