September 16, 2026, 12:44:18 am
Hoffman Amps Forum image Author Topic: Q regarding PT primary voltages  (Read 4694 times)
Offline RobBozic
« on: September 08, 2018, 04:38:58 am »
Hi,
I’ve got a 5E3 PT with 384-0-384 ac on the secondary. As I’m in Australia we use 240V.
Now on the PT primary I ground the ‘0’ and use the ‘240’, what if I ground the ‘110’ and still use the ‘240’, would I get a secondary voltage of 274-0-274? (384 - 110)
Rob
Re: Q regarding PT primary voltages
« Reply #1 on: September 08, 2018, 09:26:04 am »
You'll get about 700-0-700 until the primary winding burns open. Shouldn't take too long.
« Reply #2 on: September 08, 2018, 10:23:17 am »
...Now on the PT primary I ground the ‘0’ ...
Yikes, no!
One end of the primary connects to the mains 'neutral', the other connects to mains 'live / hot', the latter via fuse and 'power' switch.
Offline RobBozic
« Reply #3 on: September 08, 2018, 05:12:52 pm »
Yes, I meant wiring the ‘0’ to the Neutral  :smiley:
It’s for an existing amp which does work.
Rob
« Last Edit: September 08, 2018, 05:16:36 pm by RobBozic »
« Reply #4 on: September 08, 2018, 06:38:03 pm »
What Sluckey said. You would be putting 240V into 240V-110V or 130V worth of primary winding.
First thing: it sucks BIG current because the over-voltage saturates the core and current gets to 10X to 1000X normal.
Next thing: the secondary *rises* to like 709-0-709. Opposite of what you are thinking. Far too much for any g-amp.
Third thing: room fills with smoke as the over-current primary catches fire. You have turned a working PT into a stinky paperweight. (In an extreme case the cellar fuse *may* blow first; actually you should have a proper chassis-fuse which may die faster than the PT.)
You also mess with the 6.3V winding (11.6V) but I don't think it will live long enough to matter.
« Last Edit: September 08, 2018, 06:41:41 pm by PRR »
Offline RobBozic
« Reply #5 on: September 09, 2018, 07:38:42 am »
Noted, and Thanks for the reply.
Rob
