September 15, 2026, 10:38:47 pm
Hoffman Amps Forum image Author Topic: 5f2A questions  (Read 4755 times)
Offline newguitarsmell
5f2A questions
« on: September 09, 2018, 03:11:55 pm »
I am a total newbie to amp building, but am definitely addicted.
I built a 5f2A and it worked nicely but very little volume. I printed out the voltage chart and tested things against the readings. Everything was looking OK, but when I got to the 12AX7 readings there was a pop, then smoke and it looked like the 5W resistor was starting to look a bit darker...
I could have accidentally connected two of the tube lugs together (I didn't think so) or?
Before the pop and smoke, as I was trying to get a reading from the 12AX7 lugs, I was hearing ground noise in the amp.. it got louder and then bam.
The cap looks OK - but I'm thinking I should replace both?
What do you think guys?
Miss Jonesy in Oregon
Re: 5f2A questions
« Reply #1 on: September 09, 2018, 07:07:40 pm »
Welcome.
I don't see a 5W resistor in this plan. Can you show/link the plan you are working from so we are all on the same page?
Pop and smoke is bad, but unspecific. You should stand well back and power-up again. If it smokes, figure where.
Re: 5f2A questions
« Reply #2 on: September 09, 2018, 07:30:09 pm »
A lot of kit suppliers like to use a 470Ω/5W cathode resistor for the output tube.
So, can you show us some pics of your build? And a link to the layout/schematic you used?
