September 18, 2026, 05:39:44 am
Hoffman Amps Forum image Author Topic: Reducing piercing treble on this 1938 National Model B ?  (Read 11980 times)
Offline ginger
« on: September 14, 2018, 11:47:12 am »
The speaker is not the problem
Re: Reducing piercing treble on this 1938 National Model B ?
« Reply #1 on: September 14, 2018, 12:18:02 pm »
same with both channels?
same when you have the guitar treble on 0?
same at all volumes?
Offline ginger
« Reply #2 on: September 14, 2018, 12:33:57 pm »
Welll. no, guitar treble turned all the way down takes away the bite... but takes the tone away too
Offline ginger
« Reply #3 on: September 14, 2018, 12:35:41 pm »
Thanks... i will play with it today , and get back to you .
« Reply #4 on: September 14, 2018, 08:25:37 pm »
Replace the R-C network across the OT primary. This has to be a HIGH-Voltage cap! I would even ues two 0.002uFd 600V caps in series. The 4.2K (4K, 5K) should probably be 10 Watt.
Then try the same but with 0.01uFd (two 0.02uFd 600V series) with resistor. That is what I *think* it wants to be, but try the plan values first.
But it could just be an over-bright (or jammed) speaker. Being voice-coil, authentic options are few.
Offline ginger
« Reply #5 on: September 16, 2018, 08:07:55 am »
Maybe an obvious question , but... is this amp parallel single ended ?!
« Reply #6 on: September 16, 2018, 08:18:34 am »
No, it's push/pull.
Offline ginger
« Reply #7 on: September 16, 2018, 08:24:53 am »
Well... that's what I thought , until I saw the 150 ohm cathode resistor.... which , depending on "conditions" , is usually around 400 ohms . Anyway , I'm going to pull the chassis today , take voltage readings , etc .
« Last Edit: September 16, 2018, 08:33:24 am by ginger »
« Reply #8 on: September 16, 2018, 10:01:03 am »
The 150Ω resistor is lower than I usually see with 6L6s but who knows what the plate voltage is.  :dontknow:  250Ω is more common with 6L6s. But anyhow, the cathode resistor has nothing to do with whether or not the amp is push/pull or single ended.
Offline ginger
« Reply #9 on: September 16, 2018, 10:17:21 am »
Thanks , yes , I know . Seeing that resistor value made me wonder... really low... i'm about to check plate voltage now
Offline ginger
« Reply #10 on: September 17, 2018, 08:47:47 am »
This amp has had what appears to be a tone control added... which seems to do nothing... any suggestions for a tone control that may be right for this National ?
« Last Edit: September 17, 2018, 08:52:37 am by ginger »
« Reply #11 on: September 17, 2018, 09:55:02 am »
can you sketch in where it's located, values used, might help
Offline terminalgs
« Reply #12 on: September 18, 2018, 07:55:04 am »
Maybe look at those three 12uf/25v bypass caps, especially the one under the 6L6's.   you could tack in a 25uf or 47uf to see if makes a difference...
Offline ginger
« Reply #13 on: September 18, 2018, 09:00:55 am »
Yes , I'm going to replace all 12@25V  with 25@50V.... just discovered the "mystery" tone pot has no ground connection through the pot body where the .005 cap is soldered , no internal tooth lock washer .... replacing that as I post this .
Offline ginger
« Reply #14 on: September 18, 2018, 09:44:59 am »
This is the "mystery " pot ,as I see it in the circuit... replaced the pot and cap... pot still does nothing but turn off all signal at one end of the sweep
« Reply #15 on: September 18, 2018, 10:09:47 am »
I would remove it till the issue gets cleaned up.  I'm not quite good enough to tell if the 6N7s are fixed bias (real big grid R's).  If so, stitching in a TS might be more problematic.
I'd give PRR's suggestions a go, also re-cap ps, voltage checks.
does the piercing treble sound more like feedback squeal, or just too much treble.
Offline ginger
« Reply #16 on: September 18, 2018, 10:20:44 am »
Sounds like an amp with no negative feedback.... grating highs.. no squeel... no warmth
« Last Edit: September 18, 2018, 10:23:58 am by ginger »
« Reply #17 on: September 18, 2018, 10:22:59 am »
Replace that .0047 tone cap with a .01 or .022 cap. Any better?
Offline ginger
« Reply #18 on: September 18, 2018, 10:25:02 am »
I'll try that now
« Reply #19 on: September 18, 2018, 10:30:54 am »
That 6N7 is cathode biased. The grid resistor is only 250KΩ. Did you think it was 250Meg? Back during the time this amp was made, schematics used M to represent thousand (like the Roman numeral M). K (Kilo) did not show up on schematics until later. At that time M began to replace MEG to represent million. Lot of confusion during the transition years.
Offline ginger
« Reply #20 on: September 18, 2018, 10:35:06 am »
I just tried a .02 cap on the pot... signal doesn't cut out now , but tone is all or nothing at about 1 , on the 1 meg audio pot....no in between
« Last Edit: September 18, 2018, 10:48:17 am by ginger »
Offline ginger
« Reply #21 on: September 18, 2018, 10:39:03 am »
Yes , I saw the values on the schematic , and knew they had to be nonsense... A 500 meg pot ?!
Offline ginger
« Reply #22 on: September 18, 2018, 10:41:12 am »
I just wondered if this tone pot placement looked odd to your eyes
« Reply #23 on: September 18, 2018, 11:01:14 am »
Did you think
that's always been my problem  :icon_biggrin:
« Reply #24 on: September 18, 2018, 11:05:15 am »
That's exactly where I was gonna suggest you put a tone control. Try a 500K or 250K pot.
Offline ginger
« Reply #25 on: September 18, 2018, 11:22:42 am »
ok... gonna try 250K
Offline ginger
« Reply #26 on: September 18, 2018, 11:23:37 am »
Just did this... no change
Offline ginger
« Reply #27 on: September 18, 2018, 11:27:31 am »
I just want to say... It's a REAL "pleasure"... following a 1938 rats' nest circuit .
Offline ginger
« Reply #28 on: September 18, 2018, 11:36:14 am »
I'm just gonna "alligator" resistors across the pot until it works
Offline ginger
« Reply #29 on: September 18, 2018, 11:49:49 am »
No resistor value , jumpered across the pot, changes the sweep... still all or nothing
« Reply #30 on: September 18, 2018, 11:59:27 am »
Put another pot in it.
Offline ginger
« Reply #31 on: September 18, 2018, 12:00:50 pm »
Ok... second pot today... doing it now
« Reply #32 on: September 18, 2018, 12:10:23 pm »
I thought all you did was put resistors across the original 1M pot?
Offline ginger
« Reply #33 on: September 18, 2018, 12:15:31 pm »
No , today I replaced the 1 meg pot . But I just replaced THAT with a new Alpha 250K audio... I think it's working . HA... now all I have to do is solder the cap to the correctpot  lug , so it's not in reverse
Offline ginger
« Reply #34 on: September 18, 2018, 12:20:25 pm »
OK... it works... thanks. I think I may go back to the 0047 cap .  Really , thanks
Offline ginger
« Reply #35 on: September 18, 2018, 12:23:41 pm »
Although , I'm surprised that jumpering resisters across the new 1 meg pot didn't yield the same results
« Reply #36 on: September 18, 2018, 12:37:36 pm »
I'm surprised
doing service long enough you'll find there are 2 ways to deal with "that dilemma", theorizing to insanity, or go play  :icon_biggrin:
Offline ginger
« Reply #37 on: September 18, 2018, 12:49:29 pm »
I'm surprised
   Yeah , well , going to go buy batteries for my stupid camera now.... so everyone can see the insides of this thing ..... resistors from Tut's tomb
Offline ginger
« Reply #38 on: September 18, 2018, 03:28:18 pm »
PT is putting out 360V.... plate V is 405V
« Reply #39 on: September 18, 2018, 04:39:06 pm »
Note that G2 voltage is way-dropped by large dropper resistor.
This is how it used to be done. When steam engines and flatheads ruled the earth.
