September 16, 2026, 12:49:43 am
Hoffman Amps Forum image Author Topic: Blues jr Conversion, upgrades, bias  (Read 5782 times)
Offline Russ Fuquay
« on: September 19, 2018, 02:28:37 pm »
Greetings.
My first amp build is a Hoffman blues jr Conversion. I've installed the Allen TP 24 power transformer and OT20 output transformer. Why, you may ask? Well, let's say The Originals had to be replaced out of necessity and leave it at that. I figure
as long as I'm replacing them I would like to get a little more headroom and clean power if possible, but still keep the el84's at least for now.
My question is about the correct bias. Given that I'm using the OT 20 and PT 24 what should the correct bias be? Also, do any of the parts that came in the conversion kit need to be changed due to the different Transformers?
Many thanks.
Russ
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: Blues jr Conversion, upgrades, bias
« Reply #1 on: September 19, 2018, 02:58:04 pm »
The bias point isn't based upon the OT, but upon the tubes, and EL84's depend on the plate voltage coming into them.  I don't know the Blues Jr voltages, but if you look at the weber bias calculator you can get a quick check, after measuring plate voltages:
http://www.tedweber.com/webervst/tubes1/calcbias.htm
example for 350 V for EL84 class ab, it's about 24mA for 70%.
Play with the calculator, it's a great tool.
~Phil
Phil Davis
tUber Nerd =|D
Offline Russ Fuquay
« Reply #2 on: September 19, 2018, 03:27:46 pm »
Good to know. Many thanks!
Offline ginger
« Reply #3 on: October 01, 2018, 02:03:05 pm »
..... I do this on Stock Blues Juniors
« Reply #4 on: October 01, 2018, 02:14:39 pm »
That video won't help Russ. His bj no longer resembles an original or a bm modded original.
