September 16, 2026, 01:46:58 pm
Hoffman Amps Forum image Author Topic: MY AMP loves everything except the note F. WHY?  (Read 7290 times)
Offline newguitarsmell
« on: September 24, 2018, 09:22:44 pm »
My amp sounds absolutely gorgeous - then I hit the note F (particularly 8th fret A string) and I get distortion. Can somebody help me out? I tried a different speaker - no difference. I also tried a different tube --
Thoughts? Help? Should I just give up playing in the key of F?
Re: MY AMP loves everything except the note F. WHY?
« Reply #1 on: September 24, 2018, 09:34:12 pm »
I tried a different
I'd start at the other end, did you swap guitars
« Reply #2 on: September 24, 2018, 09:35:32 pm »
I will try that tomorrow....Why would my guitar be sending a crap F to the amp though?
« Reply #3 on: September 25, 2018, 09:05:43 am »
I've been fixing broke things a LONG time, "why" is for the real engineers  :icon_biggrin:
I don't play, can't tell E from A, one build the bass flabbed out, spent too much time trying to fix my amp, when I had a broke tensioner thingy in the bridge for the fattest string.
« Reply #4 on: September 25, 2018, 02:33:07 pm »
Tried two different guitars - still the scratchy sound but on different notes.
« Reply #5 on: September 25, 2018, 08:32:44 pm »
scratchy sound
that's a better description, but it leaves ALOT of possibilities
with the amp warmed up, say 5minutes, nothing plugged in, play with all the knobs, scratchy?
plug n unplug you're guitar 5-10times, then play, schratchy?
If no; with the chassis out, speaker plugged in, amp powered up, nothing at the input, take a wooden stick (chopstick) and wiggle n giggle wires, thump on solder connections, schratchy?
Offline plumcrazyfx
« Reply #6 on: September 25, 2018, 09:14:00 pm »
Sympathetic vibration and microphonic preamp tube?
Offline galaxiex
« Reply #7 on: September 25, 2018, 10:41:57 pm »
Is it a combo amp?
Some kind of resonant frequency thing.
I have a speaker cab that is "tuned' for the G at the 3rd fret 6th string.
Vibrates/rattles like hell on only that note. Any guitar.
If you sit on the cab and hit that note you get an "interesting" massage....  :laugh:
If it ain't broke, I'll fix it until it is.
« Reply #8 on: September 26, 2018, 03:49:37 am »
Drop tune the guitar a whole step. 8 fret second should now be d sharp and fret 10 your f.
Does it stay at the 8th fret? Is so, lower your pickups. If not, check your filter caps.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #9 on: September 27, 2018, 02:14:59 pm »
Had similar problem on one of my amps, did check all solder points, it fix the problem. Not saying it is the case but check it out.
https://soundcloud.com/ukiuki
