September 16, 2026, 06:04:16 am
Hoffman Amps Forum image Author Topic: Reverb  (Read 7026 times)
Offline fossilshark
  • No life til' leather
Reverb
« on: September 25, 2018, 04:22:04 am »
I want to build a spring reverb unit to go with my LA60BL clone, but I've never done anything with reverb before. I would like to go full tube but I'm open to opamps. Basically I'm asking for a schematic for something I'd be able to use after my positive ground boost into my amp. Any input is appreciated.
~SNOWBLIND~
Re: Reverb
« Reply #1 on: September 25, 2018, 05:20:33 am »
Got a schematic? What's a "positive ground boost"?
Offline fossilshark
Re: Reverb
« Reply #2 on: September 25, 2018, 06:18:16 am »
Rangemaster treble booster. I dont know if it will work with SS for the same reason positive ground pedals cant be connected to negative ground pedals.
~SNOWBLIND~
Re: Reverb
« Reply #3 on: September 25, 2018, 06:39:12 am »
Look at the 6G15
Re: Reverb
« Reply #4 on: September 25, 2018, 07:34:01 am »
Sluckey gave you good advice.
IF you want to explore some solid state options, then the 3rd page on this "one tube reverb thread" has some options to consider.
https://el34world.com/Forum/index.php?topic=7957.0
Offline fossilshark
Re: Reverb
« Reply #5 on: September 25, 2018, 10:03:57 am »
Could I use the single tube circuit like a pedal as is?
~SNOWBLIND~
Re: Reverb
« Reply #6 on: September 25, 2018, 10:25:15 am »
no
Re: Reverb
« Reply #7 on: September 26, 2018, 04:55:44 am »
IF your amp is similar to a Marshall Plexi & it had a simple passive effects loop, you could use something like this:
http://fuchsaudiotechnology.com/effects/verbrator/
« Last Edit: September 26, 2018, 04:59:32 am by tubenit »
Re: Reverb
« Reply #8 on: September 26, 2018, 05:03:44 am »
Some years ago, I made an active FX & Reverb unit that plugged into a passive effects loop.  It sound "OK" but nothing really great.
AND ……….. it still needed a full sized reverb tank with it.  So, it was NOT just a pedal that plugged in.  It was a unit that plugged into the passive FX loop and then had to have a full sized reverb tank plugged into it.
I used it for a while and then converted it into something else.
https://el34world.com/Forum/index.php?topic=10624.0
Offline fossilshark
Re: Reverb
« Reply #9 on: September 29, 2018, 09:06:58 pm »
The 6G15 has 120vdc on the output stage plate, is that safe to go into the front end of a plexi style amplifier? I mean the input stage of my amp probably has twice that on the plate. If so thats pretty much what im looking for.
« Last Edit: September 29, 2018, 09:10:44 pm by fossilshark »
~SNOWBLIND~
Re: Reverb
« Reply #10 on: September 29, 2018, 11:31:26 pm »
So? The only thing that appears at the output jack is an instrument level signal.
