September 08, 2026, 07:33:46 pm
Hoffman Amps Forum image Author Topic: DIY File library - Download .diy files or Submit .diy files  (Read 24716 times)
« on: October 01, 2018, 11:24:42 am »
I have a .diy Template File you can use to create boards that can be cut on my CNC machine
You can import this files into a current .diy file and then copy and paste them where you need them
Hoffman .diy template file is here
https://el34world.com/Forum/Files/Hoffman_Template_File.diy
I have begun uploading DIY Layout Creator files to my server
You can download and use the files in DIY Layout Creator
I plan on adding more .diy files to the library
You can also submit .diy files in a post below and I will upload them
Here's the .diy file library index page
The Fender section is based on all the Fender eyelet boards I make on this page
https://hoffmanamps.com/MyStore/catalog/EyeletBoardMobile.htm
The Hoffman section is based on all the turret lug boards I make on this page
https://hoffmanamps.com/MyStore/catalog/TurretBoardMobile.htm
There is a Template folder and a Misc file folder also in the .diy library
« Last Edit: November 13, 2018, 06:20:48 am by EL34 »
Re: DIY File library - Download .diy files
« Reply #1 on: October 01, 2018, 11:26:30 am »
If you would like to add a .diy file to the library, reply to this post down below and attach your .diy file to your post
I subscribe to this board and so I will get a notification when anyone replies in this board
File names should be in this format
Brand name_filename_model_etc.diy
Use the underscore character between words
Capitalize the first letter of the Brand name
File name Examples:
Fender_5E3.diy
Morgan_FatTone3_revsion2.diy
Marshall_JCM800_mods.diy
Vox_AC10_extra_Gain_stage.diy
« Last Edit: October 01, 2018, 12:15:43 pm by EL34 »
Re: DIY File library - Download .diy files or Submit .diy files
« Reply #2 on: January 26, 2019, 07:11:09 am »
I just updated all the fender Filter cap boards and Bias boards in the library.
They now have components in the file instead of just a board and the eyelets.
The .diy library link is here.
https://el34world.com/charts/DiyLayoutCreatorFiles.htm
