September 15, 2026, 05:01:10 pm
Hoffman Amps Forum image Author Topic: RCA Jack Ends - How to wire?  (Read 6257 times)
Offline Greenmachine
« on: October 04, 2018, 11:20:08 am »
RCA jack cable end
Can any of you fine chaps explain how I solder this jack up that Doug sells?  Thanks!
Danny
Re: RCA Jack Ends - How to wire?
« Reply #1 on: October 04, 2018, 12:16:21 pm »
I peal back the braid til there is enough center conductor to run through, and out the tip.  Strip back the tip wire ~ 3/4", tin, insert all the way and out, bend over but NOT onto the "shaft", just enough to "hook" the end.  Heat the wire and tip together with a clean iron til the solder wicks into the hole and seals.
I then fanout and trim the shield evenly around the back tapered part, solder ~ 1/2 way around rotate everything and reflow the rest.
no blobby globbies, smooth flow, caution with heat, especially the center so you don't melt the center wires coating.
buy 5, by the 5th one you're a pro, use good wire, good solder, clean parts
« Reply #2 on: October 04, 2018, 12:40:35 pm »
Shooter, you are the man! :worthy1:
« Reply #3 on: October 04, 2018, 01:14:30 pm »
This is how it was done in the '50s and '60s before all those fancy RCA plugs showed up. Look at the black wire. It was stripped about 1-1/4", tinned, wrapped tightly around the shell, then soldered. Do this before putting the white wire in the center to avoid melting the white insulation. Then strip the white wire about 3/4", tin, shove it up the center pin until it bottoms out. The end of the wire should poke out the end of the center pin. Solder, allowing the solder to wick down into the center pin. Trim the excess wire. If you want a nice pretty rounded end, reheat and put a shiny ball of solder on the end of, kinda like putting a shiny ball on the top of a turret.
Use the same procedure when working with shielded cable. Note... If you use Teflon RG-316 you don't have to worry about melting the center conductor.
Offline Heddok
« Reply #4 on: October 04, 2018, 02:53:26 pm »
Sluckey
Thanks for that,  I've never soldered those types before.  I'm waiting for my 5F6a parts and will be soldering 4 of those.
« Reply #5 on: October 04, 2018, 08:58:24 pm »
:laugh: those guys taught me in the '70s n being a poo boy that could solder, I made a few $s fixing broke wires, could get good $s for wiring up an ignition "hot wire" switch  :icon_biggrin:
« Reply #6 on: October 05, 2018, 03:43:13 pm »
Sluckey -thanks for the info..
« Reply #7 on: November 26, 2018, 10:46:01 am »
I just ran across this pic while browsing through some old HeathKit manuals...
« Reply #8 on: November 26, 2018, 11:11:28 am »
 :laugh:
by my 3rd Heathkit I got pretty good at melting solder!
« Reply #9 on: November 26, 2018, 11:44:18 am »
Yeah, there was a lot of good basic technique stuff in those HeathKit manuals. Here's another pic I wish everyone that ever wanted to solder something electronic could see...
