September 17, 2026, 08:46:29 am
Hoffman Amps Forum image Author Topic: Scratchy sounding 6SL7.... tube or amp?  (Read 5447 times)
Offline 1blueheron
« on: October 15, 2018, 02:16:44 pm »
I ordered a new JJ 6SL7 to go in the Webster amp that Sluckey helped me modify.  I have been running it with a 6SN7 in that socket and it has worked perfect and been dead quiet.
Well, the new 6SL7 came Fri. and I put it in its position with great expectations.   Turned it on and it sounds like someone playing a scratchy record or tuning in a radio.  Lots of hissing and scratching.  No real pops, more like intermittent white noise at various levels.  Put the 6SN7 back in and its dead quiet again.
I plan to swap positions between 6SL7's tonight and see if it makes a difference but I am thinking they sent me a bad tube.
Any thing I can do to definitively determine it is not the amp ar that would say for sure it is the tube?  I don't have a tube tester.
Re: Scratchy sounding 6SL7.... tube or amp?
« Reply #1 on: October 15, 2018, 02:27:19 pm »
do that
« Reply #2 on: October 15, 2018, 04:48:49 pm »
Also, you might let it "cook" for 24hrs or so, The last 3-4 AU7's I bought new were really sketchy but after about 20hours of "variations" each has settled down to "known good, tested"
« Reply #3 on: October 15, 2018, 07:43:37 pm »
I love 6SL7, but that sure sounds familiar.
Offline terminalgs
« Reply #4 on: October 16, 2018, 07:22:55 am »
try a AC signal ground on the grids, if the noise goes away.  with something like this,  one side to ground, the other to grid:
capacitor can be .0.5uf or bigger.  if its a gains stage with 0vdc on the grid, you can just ground the grid.
I'd get ready to return the 6SL7.   if you didn't hear any noise with the 6SN7, but you do with the 6SL7 then probably a crummy tube.  If you heard the same noise, only it was quieter with the 6SN7, that's a different story...
