September 17, 2026, 09:45:09 am
Hoffman Amps Forum image Author Topic: High pitch sequel or low frequency hum with Feedback circuit off  (Read 4385 times)
Offline smilch
Just finished building a blues JR from the Hoffman kit . the amp was sounding pretty good and then I noticed I forget to hook up the feed back circuit . Thats when trouble arose . When the pot is turned off there is a high pitched squeal  coming from the speaker . turning all other pots switches make no difference , except the meat pot As soon as the pot is turned half way or more up the noise goes away . I checked connections and found a bad ground at the 4.7K resistor in the circuit going to the Meat Pot ..
Im sure someone has run into this . Just looking for some starting point suggestions .
Re: High pitch sequel or low frequency hum with Feedback circuit off
« Reply #1 on: October 27, 2018, 05:46:53 pm »
Swap the OT primary plate leads.
Offline smilch
« Reply #2 on: October 27, 2018, 09:52:48 pm »
That was easy . problem fixed
