September 17, 2026, 08:43:01 am
Hoffman Amps Forum image Author Topic: questions about a capacitor on pp power tube kathodes  (Read 4314 times)
Offline ALBATROS1234
« on: October 28, 2018, 01:12:16 pm »
latest project is a harp amp for a friend. i am esentially doing only the microphone input/channel of an older gibson ga-20. i am soldering it up and connected to the cathodes of the power tube there appears to be a cathode bypass cap. it is 20uf so that makes sense but the placement seems odd as it appears to have both sides connected to ground/negative. it does not indicate if it is an electrolytic (polarized) or film(nonpolarized) just kinda confused about this. below is the schematic.
Offline VMS
Re: questions about a capacitor on pp power tube kathodes
« Reply #1 on: October 28, 2018, 01:23:28 pm »
I think it's electrolytic and heaters are elevated with power tubes cathode voltage. This schematic shows it more clearly:
https://el34world.com/charts/Schematics/files/Gibson/Gibson_ga20_12ay7_preamp.pdf
« Reply #2 on: October 28, 2018, 01:28:46 pm »
It's badly drawn, faded, brutally scanned.
Fix the missing cross-overs. Dot the connections. Crayon the main buses.
The 20u is across the 220r and this point is about +15V or +20V. This is also extended (blue line) to the heater CT, to "raise the heaters".
Or what VMS said while I was playing with crayons.
« Last Edit: October 28, 2018, 01:31:23 pm by PRR »
« Reply #3 on: October 28, 2018, 01:46:16 pm »
aaah gents thanks much, this is kinda what i was thinking but as you saw the schematic was pixelated and funky. that makes sense more how the later version is drawn
