September 17, 2026, 08:25:14 pm
Hoffman Amps Forum image Author Topic: 3k vs 1.7k in OT's?  (Read 4630 times)
Offline Oddvar
3k vs 1.7k in OT's?
« on: October 31, 2018, 12:42:30 pm »
Hi.  Is there any significant difference between 1.7k and 3k ohms in an output transformer, or are they interchangeable?
Re: 3k vs 1.7k in OT's?
« Reply #1 on: October 31, 2018, 12:53:20 pm »
3K or 3.4K might be used with a pair of EL34s. 1.7K might be used with a quad of EL34s.
Offline Oddvar
« Reply #2 on: October 31, 2018, 01:10:29 pm »
So it won't be usable with 4 6l6?
« Reply #3 on: October 31, 2018, 01:20:08 pm »
Sure. Which one?
Offline Oddvar
« Reply #4 on: October 31, 2018, 01:52:39 pm »
I am thinking of using it in a Dumble build...
« Reply #5 on: October 31, 2018, 03:34:35 pm »
If I had one, I'd use this OT in a #183 build...
Offline SoundmasterG
« Reply #6 on: October 31, 2018, 09:29:58 pm »
6L6's tend to like something closer to 2k for a quad and EL34's are very happy with 1.7k, but they will both work with either. The B+ used changes the optimum load as does the bias you set it to. There is a range of impedance that works with every tube type rather than a hard set value.
Greg
« Reply #7 on: November 01, 2018, 08:48:24 am »
happy with 1.7k,
fwiw I used a 1.2k with a Quad SE of EL 84's in a Fi build  ~20W clean
