September 08, 2026, 12:05:24 pm
Hoffman Amps Forum image Author Topic: New (to me) Holiday / Harmony Stratotone  (Read 7754 times)
Offline dbishopbliss
    • Bliss Amplifiers
« on: November 13, 2018, 11:16:05 am »
I just bought a Stratotone that has seen better days. Based on the serial number it appears the guitar was originally a Holiday version of the H45.
The electronics weren't working properly (tone control did not work) so I opened it up. The fix should be fairly simple because the capacitor has one leg disconnected.
However, there are a number of suspicious values that makes me question if the pots/caps are original. Specifically, the volume pot appears to be 5K. From what I understand the Stratotones used to have 50K pots. I cannot find 50K pots on guitar supply sites. Any reason why I should not use a 250K pot or use one of these:
https://www.mouser.com/ProductDetail/Alpha-Taiwan/RV16AF-10-15R1-A50K-0DLA?qs=sGAEpiMZZMtC25l1F4XBU1WvpdUcjC%2f68kiQFMX4jVD7gLypQ6Rx2A%3d%3d
Check out my blog for more details. Bliss Amplifiers
Re: New (to me) Holiday / Harmony Stratotone
« Reply #1 on: November 14, 2018, 10:44:38 am »
If you can't find a 50K pot, the simple solution is to parallel a 100K pot with a 100K resistor.  For more info and stuff about pot taper, see:  http://www.geofex.com/Article_Folders/potsecrets/potscret.htm
The pot does not exist in isolation, but also in conjunction with any tone cap, forming an R-C network.  This is a directly variable relationship: e.g., if you double the R value, you halve the C value and get the same tone curve.  The pot also functions with the impedance, inductance and capacitance of the guitar PU: so changing the pot value alters tone - higher pot value > brighter tone.
« Reply #2 on: November 14, 2018, 11:12:44 am »
