September 17, 2026, 11:53:36 am
Hoffman Amps Forum image Author Topic: Zener diode placement  (Read 4767 times)
Offline Diverted
« on: November 14, 2018, 09:54:50 am »
Hi all,
I'm building a Fender standalone reverb clone, with a power transformer that puts out about 310v with no load. I'm expecting it'll still be a little high once I get it all wired up. The HV secondary does not have a center tap. I've used Zeners before to reduce voltage, putting them in the center tap leg. Without that center tap, I'm wondering about placement. Assuming I just run them on one of the two HV taps?
Ted
Re: Zener diode placement
« Reply #1 on: November 14, 2018, 10:03:00 am »
Put the Zener between the bridge positive terminal and the filters. Or put it between the bridge negative terminal and ground.
Offline d95err
« Reply #2 on: November 14, 2018, 10:07:54 am »
You could simply use a resistor between the rectifier and first filter cap to bring the voltage down. As it’s all class A, it will not introduce any sag. You will also get better filtering (less hum/buzz).
Offline Diverted
« Reply #3 on: November 14, 2018, 03:11:15 pm »
Thanks for the tips! I'll try various resistance until I find something in the ballpark. Much obliged,
Ted
PS: Using 10-25W resistors dependign on value.
« Reply #4 on: November 14, 2018, 08:46:54 pm »
If it's anything close to this one;
http://el34world.com/Hoffman/files/Hoffman_6G15.pdf
I think
310v with no load
will fall really close to a good spot loaded
