September 08, 2026, 04:22:56 pm
Hoffman Amps Forum image Author Topic: AA battery charger  (Read 8305 times)
Offline Tommynz195
AA battery charger
« on: November 18, 2018, 08:17:06 pm »
looking for a battery charger would you not recommend or recommend any of these?
have recently learnt my eveready overnight charger has NO clue if the battery is dead or 99% charged that goes in
at the very least I just want a charger that will cut off each battery when it is charged and not cook it my batts
This panasonic ones I have seen only diff seems to be a $10 cost and a high drain device set of battery
Panasonic K-KJ55MCC4TA 3hr Quick Charger + 4 x AA eneloop batteries
Panasonic K-KJ55HCC4TA 3hr Quick Charger + 4 AA eneloop PRO batteries
varta 2 HR lcd Charger Model Number57270412451
In New Zealand a lot of sites seem to have a less than basic blurb.
Buy our junk cos thats all you found so far, oh and we have junk available for you
Obviously I am not saying panasonic is junk, they produce a nice something.
all input appreciated
« Last Edit: November 19, 2018, 12:32:49 am by Tommynz195 »
Knowledge not shared is Knowledge wasted.
Re: AA battery charger
« Reply #1 on: November 19, 2018, 08:54:42 am »
at the very least
That can be as simple as a voltage comparator, or as complex as my Outback 60
If it's not stated in the spec section, assume it's to dumb to buy
« Reply #2 on: November 22, 2018, 05:28:45 pm »
I have good luck with this one.
It does 18650's also, which I have several flashlights that use 18650's
It runs on 12 volts or line
I use it in my RV van most of the time
https://www.amazon.com/gp/product/B00LCLPO3O
There are others on Amazon that look good
Like this one
https://www.amazon.com/dp/B071J413F9/?coliid=I19HIAUX7DZSM8
« Last Edit: November 22, 2018, 05:32:13 pm by EL34 »
