September 08, 2026, 11:22:01 am
Hoffman Amps Forum image Author Topic: Pickup question  (Read 6966 times)
Offline davidwpack
    • My music on reverbnation
Pickup question
« on: November 25, 2018, 07:42:33 am »
Ello. If anyone here has wound their own pickups, have you wound them in such a way that you could access the poles individually? For example, when i try to set eq I get the treble strings to sound good the bass strings sound muddy. Then I get the bass strings to sound defined the treble strings sound ear-piercing. If I had a setting that the treble poles we're accessed on the neck pick up and the bass poles we're accessed on the bridge pickup I would never require any other pickup selection. I wouldn't even need a switch. I feel like this a stupid question and that the only way to do that is to wind my own pickups with only 3 poles of each wired up. I just thought someone may have done something like this or know someone that makes custom pickups like that. Anyone? Thanks...Dave
Offline davidwpack
Re: Pickup question
« Reply #1 on: November 25, 2018, 07:47:10 am »
Also, I've always had this situation with any guitar with any amp. O.C.D. maybe?
Offline simonallaway
    • Hot Bottles - Tube Amp Blog
Re: Pickup question
« Reply #2 on: November 30, 2018, 11:44:36 am »
I battle with that occasionally. The tones I go for need plenty of attack for all notes. I don't like flubby bass. And I find I'll lose attack (due to compression) in the low end way before the top goes. So I run my amp quite bright and use the tone control on my guitar.
However, once upon a time you could get multi-output pickups from a guy names Ripley. I think Allan Holdsworth tried them at one point in his quest for weirdness (which led him instead to the SynthAxe).
https://reverb.com/item/138142-kramer-ripley-1985-black
Offline davidwpack
Re: Pickup question
« Reply #3 on: December 01, 2018, 02:03:39 pm »
Hey. Thanks for the info!
Offline davidwpack
Re: Pickup question
« Reply #4 on: December 06, 2018, 08:10:26 am »
Anyone here wind pickups and want to make a few bucks? I'd only need 3 poles of each pickup wound with one output of each pickup (P-90).( EAD poles of bridge pickup and GBE of neck pickup.
