September 15, 2026, 05:58:51 pm
Hoffman Amps Forum image Author Topic: Size for first two filters  (Read 4866 times)
Offline dude
« on: November 26, 2018, 01:24:39 pm »
If I wanted to make a 6V6 Plexi but wanted to be able to use EL34's too, instead of two filter cans at 32/32uf would it be better to use the first can at 50/50uf, other at 32/32uf ? Using GZ34 R tube or 5AR4 or diodes.
Also the bias caps, would 10uf @ 100v be good enough for the larger tubes, 6L6s, EL34's?
al
Re: Size for first two filters
« Reply #1 on: November 26, 2018, 01:48:57 pm »
PS filtering depends 1st on what regulator, some tube type have max cap values, SS loves anything withing reason, I use 50 - 100uf.
next comes the magical PS sag, it's to complex for me so I design to have none, or very little, one less thing to fret about  :icon_biggrin:
« Reply #2 on: November 26, 2018, 02:52:11 pm »
Doug uses 10uf in both the 6V6 plexi and Plexi 50 bias circuits  so you should be good to go with either one..
a good read on bias supplies is here  http://www.valvewizard.co.uk/bias.html
In Dougs 6V6 plexi he uses a 40uf before the choke. In the 50watt plexi there is 100uf capacitance as the reservoir filter.   Since either one has a solid state rectifier then there are no constraints
placed by a rectifier tube as to input capacitance. I would think that using 50/50uf can up front would be ok for both.
« Last Edit: November 26, 2018, 03:01:15 pm by mresistor »
Offline dude
« Reply #3 on: November 26, 2018, 04:06:21 pm »
That's what I was thinking, 50/50 first can, choke between the two 50uf's.
al
