September 16, 2026, 06:24:08 pm
Hoffman Amps Forum image Author Topic: Hoffman AB763 vs Leo Fenders  (Read 6608 times)
Offline etneccas
« on: November 27, 2018, 07:35:30 pm »
Looking for clarification on Deluxe Reverb AB763 The phase inverter V5-3 on Fender has
a 47ohm resistor going to ground
Hoffman’s shows a 4.7k in parallel with a .22 electrolytic going to ground
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: Hoffman AB763 vs Leo Fenders
« Reply #1 on: November 27, 2018, 08:44:36 pm »
Not sure i'm following:
https://el34world.com/charts/Schematics/files/Fender/Fender_deluxe_reverb_ab763.pdf
and https://el34world.com/Hoffman/files/Hoffman_AB763_2.pdf
both show a 47 ohm to ground after the typical identical PI setups.  What are you referring to?
~Phil
Phil Davis
tUber Nerd =|D
Offline etneccas
« Reply #2 on: November 27, 2018, 08:59:15 pm »
The second link you posted shows the 4.7k red and the.22cap ?.....
that’s whats confusing me
Where did you reference the Hoffman schematic with the 47ohm to ground?
« Reply #3 on: November 27, 2018, 09:03:22 pm »
First, V5 is not the PI tube. It is the tremolo tube. And Hoffman's trem circuit is not the same as the AB763 trem circuit. Neither circuit has a 47Ω resistor in it. The AB763 Deluxe has a 2.7K and 25µF from v5-3 to ground. Hoffman's circuit has a 4.7K and 22µF from V5-3 to ground.
    • Daviszone
« Reply #4 on: November 27, 2018, 09:09:42 pm »
Oh yeah didn't even note that, I kept 'Phase inverter' in head and was trying to understand what was the reference.  So yes, from what sluckey shows, there's a slightly lower capacitance for the cathode cap, but nothing too major.  as for the 4.7k it's probably to bias that tube a bit cooler, so it's got more clean output, but that's just a guess.  I'd wager Doug made that change from personal testing and he preferred it that way.  You can easily swap back to fender stock for a few dollars if you want.
~Phil
Phil Davis
tUber Nerd =|D
« Reply #5 on: November 27, 2018, 09:27:32 pm »
Read this...  https://el34world.com/Hoffman/AB763Notes.htm
Hoffman's AB763 does not use the optocoupler trem circuit found in a real AB763 amp. He uses a bias vary trem circuit from the 6G16 Vibroverb amp.
     https://el34world.com/charts/Schematics/files/Fender/Fender_vibroverb_6g16_schem.pdf
That accounts for all the differences in the V5 circuit.
Offline etneccas
« Reply #6 on: November 28, 2018, 09:00:33 am »
My bad ...I could still use some clafication as to why Doug has R45 a 100 ohm resistor instead of a 40 ohm at V6?
Offline etneccas
« Reply #7 on: November 28, 2018, 09:17:05 am »
Nevermind I found the answer in the BOM the Deluxe Reverb uses a 47 ohm......
Thanks for the clarification on the tremolo circuit
« Reply #8 on: November 28, 2018, 09:22:07 am »
Then look at the BOM.
Nobody uses a 40Ω resistor. Leo used a 47Ω when the NFB came from the 8Ω tap on the OT. He used a 100Ω when the NFB came from a 4Ω or 2Ω OT tap. Hoffman is just following Leo's lead.
