September 16, 2026, 07:26:09 pm
Hoffman Amps Forum image Author Topic: Fixed and self bias  (Read 4668 times)
Fixed and self bias
« on: December 05, 2018, 05:39:29 pm »
I should know this but don’t!  :think1:
You start with fixed biased amp, and 1ohm Rk for current calcs.
now I up Rk to 10 ohms cuz I want to made things hard, and re-bias the fixed side – if needed.
If I keep uppin Rk n tweaking fixed, can I get to a point where even and odd harmonics “balance”, unintended consequences, or am I just wasting gray matter n cloud space  :dontknow:
Re: Fixed and self bias
« Reply #1 on: December 06, 2018, 02:26:17 pm »
It's complicated. And maybe not worth much.
Quit picking your brain and apply the soldering iron.
« Reply #2 on: December 06, 2018, 03:05:09 pm »
It's complicated.
 :laugh:
ya, it's stuck in an endless loop!  I'm doing woodworking outdoors so my brain just shuts down  :icon_biggrin:
« Reply #3 on: December 06, 2018, 06:50:44 pm »
Maybe that's what Fender hoped when they went from BF to SF.
Anyway 10R can act as fuse & bias sense.
« Reply #4 on: December 06, 2018, 07:25:00 pm »
10R can act
That's what got the whole mess in my brain started, Willabe's KT88 conversion.  The PA tubes use 10r guessing as the "correct" value for the meter's, Then...........  :think1:
I have a small understanding of amp history, and a quick search only yielded spy vs spy instead of working together.
I'll be getting the soldering gun out soon, gotta wire up lights for my ghetto camper II  :icon_biggrin:
« Reply #5 on: December 06, 2018, 07:55:53 pm »
Few power tubes have Gm as low as 1/50r, so a "significant" resistor will be 100 Ohms up.
10 Ohms was standard when good meters read 1.5V on the lowest range. 50mA was 0.5V or 1/3rd-scale, you can read that. With 1 Ohm it is 0.050V, hard to squint on a 1.5V scale. But sweet on DVMs where the natural input is 199mV.
