September 08, 2026, 01:11:41 pm
Hoffman Amps Forum image Author Topic: Friedman Smallbox 50 Layout  (Read 24798 times)
Offline purpletele
    • Vallis Enterprises, Inc.
« on: December 12, 2018, 07:53:40 pm »
I came across a layout diagram for a Friedman Smallbox 50.  I have been gassing for one of these amps and started looking for schematic and layout info just for fun.
Maybe someone can design a turret board.  Still searching for a schematic.
Re: Friedman Smallbox 50 Layout
« Reply #1 on: December 12, 2018, 08:03:08 pm »
Maybe someone can
I got this far  :icon_biggrin:
http://el34world.com/Forum/index.php?topic=23937.0
Offline purpletele
« Reply #2 on: December 13, 2018, 01:42:13 pm »
Offline Ledzepp007
« Reply #3 on: January 17, 2019, 09:05:50 am »
For most of us, we’d have to tap the B+ to get the ~10-15VAC needed for the DC heaters.
« Reply #4 on: January 17, 2019, 09:12:05 am »
How would you do that?
Offline Ledzepp007
« Reply #5 on: January 17, 2019, 10:54:00 am »
Great question. I suppose in theory one would treat it like a second bias supply: use a sufficient dropping resistor to get the VAC to an acceptable range, rectify it, smooth it, and then regulate it to 12VDC. The max VDC for that regulator is 35, so the rectified, smoothed voltage would need to probably be between 15 and 25 VDC.
I suppose one could use the 6.3VAC tap and a voltage doubler, but I’m not sure you’d be able to handle the current of three 12AX7 filaments.
« Reply #6 on: January 17, 2019, 11:07:00 am »
Each 12AX7 will want 150mA to light up properly. I doubt you'll be able to get that kind of current from a typical high voltage winding after going through a resistor sufficient to drop the voltage to 12V.
Offline Ledzepp007
« Reply #7 on: January 17, 2019, 11:47:48 am »
So one would either need to do a custom transformer, have a separate filament transformer, or use the voltage doubling technique (with a transformer that has a sufficiently high current rating for the heaters)?
« Reply #8 on: January 17, 2019, 12:06:26 pm »
All those methods are viable options. Just rectifying/filtering a 6.3VAC source is fine too. Just use a single low resistance/high wattage resistor to drop the voltage to 6VDC for the tubes. No need for a regulator since the load current is constant.
