August 29, 2026, 03:57:23 pm
Hoffman Amps Forum image Author Topic: Shielded cables  (Read 4377 times)
Offline Swampertech
Shielded cables
« on: December 13, 2018, 04:26:18 pm »
Are all "long" runs (2"-5") in the circuits before the phase inverter less likely to pick up hum if shielded cable is used?
Re: Shielded cables
« Reply #1 on: December 13, 2018, 04:36:11 pm »
generally anything past V1 has a large enough signal not to cause problems as long as you use best practices.
shielded wire from input to V1, and sometimes TS out to TS recovery tubes is where I typically use it.  Remember, only ground ONE end of the shield, usually at signal source
Offline Swampertech
Re: Shielded cables
« Reply #2 on: December 13, 2018, 04:44:40 pm »
Thanks Shooter. I'm building a cascaded front end, with the Lead Channel (Rob Robinette) being switched into the Bright Channel through a relay. I have the relay located as close to the input channels as possible. Would any cathode lines need to be shielded?
Re: Shielded cables
« Reply #3 on: December 13, 2018, 05:24:19 pm »
any cathode lines
anything  signal < ~ 100mV I'd consider shielding.  I'm not a fan of relays n switches so you'll have to see what other successful amps do.
Offline Swampertech
Re: Shielded cables
« Reply #4 on: December 16, 2018, 07:01:07 am »
Shooter,, one quick question. To troubleshoot noise in the preamp section section of a 5E3, is it acceptable to ground the grids of the 12AY7 to eliminate each section?
