September 19, 2026, 12:27:08 pm
Hoffman Amps Forum image Author Topic: SUNN 200s  (Read 7201 times)
Offline ernie_jr
  • gimme a banana
SUNN 200s
« on: December 15, 2018, 12:47:15 pm »
Has anyone when re-building a SUNN 200s ever tap the b+ from node A (before the choke) instead of node B (after the choke)?
If so, what were your results?
Ernie
Re: SUNN 200s
« Reply #1 on: December 15, 2018, 12:53:25 pm »
I have not done that but I'm curious... Why would you even want to?
Offline ernie_jr
  • gimme a banana
Re: SUNN 200s
« Reply #2 on: December 15, 2018, 01:00:39 pm »
I noticed that on the Fender 135 w UL amp the first node was used, so just currious.
Ernie
Re: SUNN 200s
« Reply #3 on: December 15, 2018, 01:27:49 pm »
Did you also notice that the Fender doesn't even have a choke?
Offline ernie_jr
  • gimme a banana
Re: SUNN 200s
« Reply #4 on: December 15, 2018, 01:33:42 pm »
yes I did, thanks, interesting since they used choke in the pentode designs.
Ernie
Re: SUNN 200s
« Reply #5 on: December 15, 2018, 04:09:33 pm »
These are HIGH-voltage amps. The filter capacitor cost becomes an issue.
Sunn's approach was to use a small cap, giving high ripple voltage, and then a choke and another cap.
The voltage at the first cap is far from "smooth". My Idiot says almost 60 Volts ripple, over 11%. However at the second cap (after the choke) under 2V, under 1%.
Now you go over to Fullerton. The F-135 is actually a bigger amplifier. Moreover I believe Sunn was good friends with a winder, while Fender bought open market. And we know Leo was an accountant (not sure about CBS). Whatever, Fender designed with BIG capacitors and no choke. Works out to 26V ripple which is just barely 5% which is typically a cost-effective place to be.
If you move the Sunn plan over, you have a hair more B+ average but a lot *less* voltage in the dips. Max "clean" power will be lower. At high power the 120Hz buzz may be obnoxious. AND you paid for, and have been carrying, that large lump of iron choke. You have it, use it.
Re: SUNN 200s
« Reply #6 on: December 15, 2018, 04:43:11 pm »
Unlike the PT and OT, the choke in those old Sunns is quite small...
Offline ernie_jr
  • gimme a banana
Re: SUNN 200s
« Reply #7 on: December 22, 2018, 07:33:08 am »
Good reading, thanks PRR.Ernie
Offline billcreller
  • 1934
Re: SUNN 200s
« Reply #8 on: December 30, 2018, 07:18:20 pm »
I re-capped one of those a while back.  The bass player/owner loves that amp now.  It was left in a rental house & not claimed, so he go it for nothing !  Even the cab cleaned up great ....
