September 17, 2026, 11:56:19 pm
Hoffman Amps Forum image Poll
do i need to change any resistor or capacitor value?
what is the biasing for changing MIG 50 power transformer?
0 (0%)
what is the best way to lower the voltage on output tube plate  in MIG 50 ?
0 (0%)
Total Members Voted: 0
Hoffman Amps Forum image Author Topic: Sovtek Mig 50 power transformer change  (Read 5721 times)
Offline Ansel
« on: January 05, 2019, 01:19:56 pm »
i'm interested in changing the power transformer in the MIG 50 with VOX AC30  type power transformer for lower voltage on B+, any other suggestion?
MIG 50 :
The plate sits at around +535V and the screen at +530V. The bias voltage is about –58V and the input impedance for the OT is 4.75K Ohms
the AC30 type power transformer gives a  290vac secondary , and with the MIG 50 bridge rectifier it will give about 290/0.71= 408vdc which is very fair on the B+ and ofcourse it will be less on the screen
my question , if i do this change , do i need to change any resistor or capacitor value? or just tweaking the bias knob for the grid?
Re: Sovtek Mig 50 power transformer change
« Reply #1 on: January 05, 2019, 01:28:24 pm »
Welcome.
Just changing the main B+ down about 24%, no radical change needed. G1 bias should be approximately 408/535 of present 58V, around 44V. That straight-line interpolation is a little off, but all tubes vary, so you will dial-in from there while observing cathode currents and plate dissipation.
« Reply #2 on: January 05, 2019, 01:42:28 pm »
Some AC30s use a PT meant for a FWB, others use a PT meant for a conventional FW rectifier. Be careful to pick the correct PT to use with your Mig FWB, or you may end up with twice as much B+ as you want! Also, you'll probably need to modify the bias circuit since the AC30 PTs don't have a bias winding. Fairly simple but it is a big deal.
Offline purpletele
    • Vallis Enterprises, Inc.
« Reply #3 on: January 10, 2019, 11:59:43 pm »
I didn't know that we have the polling option,
My poll would be something like, I have re-wired and changed every component:
a. Do you think that little voltage issue took out my OT
b. Should I stick to just playing guita
« Last Edit: January 11, 2019, 12:05:38 am by purpletele »
