September 18, 2026, 01:57:08 pm
Hoffman Amps Forum image Author Topic: Not a Guitar Amp  (Read 8722 times)
Offline p2pAmps
    • p2pAmps
Not a Guitar Amp
« on: January 06, 2019, 09:09:36 am »
This is something I have been meaning to build for awhile now, a cool hifi amp.  Sure glad I did as it sounds amazing.  Sporting 4 KT120s, 5AR4, and 3 12AU7s...  Nice change of pace
Everything Affects Everything
Re: Not a Guitar Amp
« Reply #1 on: January 06, 2019, 01:32:50 pm »
 :thumbsup: :thumbsup:
« Reply #2 on: January 06, 2019, 01:51:22 pm »
That's remarkably cool!  What a fantastic project!  THANKS for sharing your success with it.   :thumbsup: :thumbsup:
« Reply #3 on: January 06, 2019, 02:30:54 pm »
nice. but why is choke on the left side anchored with only one bolt/nut?
« Reply #4 on: January 06, 2019, 02:33:56 pm »
amazing workmanship, and the octals for speakers, killer!
using DC filaments?  I see a bridge under but a tube rec above
Offline p2pAmps
    • p2pAmps
« Reply #5 on: January 06, 2019, 09:02:30 pm »
Hey Shooter, yeah, DC filaments for sure.  The small circuit board is a TDR for a slow start should I decide to use a SS rectifier (no bridge). These amps are very cool and give a McIntosh a serious run for the money
Offline p2pAmps
    • p2pAmps
« Reply #6 on: January 06, 2019, 09:03:50 pm »
I know huh LOL.  Thats the way the chassis was drilled and I didn't want another hole in the top so I let it sit the way it sits.  It's not causing a problem but does kinda rub me the wrong way too :)
« Last Edit: January 06, 2019, 09:06:22 pm by p2pAmps »
Offline p2pAmps
    • p2pAmps
« Reply #7 on: January 06, 2019, 09:05:22 pm »
BTW, those two switches in the middle are triode/pentode switched, kinda cool.  I'm using it on the triode ultra linear mode which is more powerful and sounds good for the stuff I'm listening to.
« Reply #8 on: January 07, 2019, 05:16:58 am »
so what's the amp using to drive the air
Offline p2pAmps
    • p2pAmps
« Reply #9 on: January 07, 2019, 05:39:53 am »
The rest is a McIntosh MX130 pre, Marantz 6300 turntable, and a set of JBL 120ti speakers.  Next I will build a tube pre and a DAC...
« Last Edit: January 07, 2019, 05:49:25 am by p2pAmps »
« Reply #10 on: January 07, 2019, 08:00:55 am »
Big time soup up of a Dyanco.  Tube pre.  I go back and fourth.  I have a very nice Marantz type tube pre I have built.  I have too much junk anyway.  This looks great.  Where did you source the chassis?
« Reply #11 on: January 07, 2019, 08:57:42 am »
don't know if his is from the same source, but you can get one here ed.
« Reply #12 on: January 07, 2019, 10:08:24 am »
That is too cool and affordable considering some of the extreem cork sniffer kits and finished products out there.
I hope this isn’t too much of a hijack...  I went on their website and noticed an auto-bias circuit. How does this work?
« Reply #13 on: January 07, 2019, 10:19:49 am »
« Reply #14 on: January 07, 2019, 11:20:43 am »
That's a really nice amp..  did you get the driver cover for it too?
« Reply #15 on: January 07, 2019, 12:28:12 pm »
@Jim:  https://forum.audiogon.com/discussions/quot-fixed-quot-bias-versus-quot-auto-biasing-quot
Another dynaco-type kit source:  http://www.tubes4hifi.com/bob.htm
JJ thanks for that. And that is the site for P2P’s amp. I was just wondering how the auto bias works. It sounds like automatic antenna matching for my Ham radio with servos. I was just wondering how the comparative circuit works?  As someone who does “atmospheric biasing”, I don’t know if I could trust that!!!
« Last Edit: January 07, 2019, 12:31:13 pm by Ritchie200 »
Offline p2pAmps
    • p2pAmps
« Reply #16 on: January 07, 2019, 12:47:21 pm »
Offline p2pAmps
    • p2pAmps
« Reply #17 on: January 07, 2019, 12:48:31 pm »
Nah, I kinda like staring at those KT120s!   :icon_biggrin:
« Reply #18 on: January 07, 2019, 01:00:19 pm »
Jim, I'm not sure the guy's right.  Some hi-fi purists opt for a voltage regulated bias supply.  That keeps the bias voltage constant regardless of B+ sag.  This would result in cold bias under strong signal conditions.  So they might also regulate the B+ supply.  This results in a lot of statistical performance claims, but I don't know if there's a real tonal difference.
Some hi-fi purists don't like B+ or bias voltage moving around on principal.  I think they claim it will modulate output power causing a tremolo affect which is not true to the original signal.  Maybe they're technically right???
FWIW I think McIntosh used a more passive feedback circuit to eliminate the need for bias adjustment.
« Reply #19 on: January 07, 2019, 01:47:12 pm »
wondering if bob's amp melted down. the one monoblock on the right is not happy in the pic.
